Anyone using the Phillips Nivea shavers here?
I have tried other electric/battery shavers and always
seemed to get a rash from them.
Does the Phillips Nivea shaver stop you from getting this
rash?
Designer stubble is in 🙄
Any shaver with Nivea in the name is a bit er...
Assume you mean coolskin and Achitect/tas or whatever (3 heads that you load with fluid)
I use, with can gel std gel - cheaper and appears to work, found the old 7780 or whatever it is (ie not the thin neck carry on) good, new three head on a thin neck (8260???) or siumilar (*1/2price boots maybe) not quite so good but tried a braun cruzer 3(??) and actually threw it out after trying for a couple of weeks.
Yes they are very good. Not as good as a wet shave but if you tend to get a rash with electric then the Philips Coolskin is the answer imo.
Thanks for replys I bought the Phillips HS8440
half price from Boots £ 73.00p
Brilliant shave and will save me money
Much cheeper than buying Gillette Mach 🙂 blades
