Pergola or Gazebo.....
[Closed] Pergola or Gazebo....middle class decision time.
Right, the shower's been regrouted and sealed.
My next task this Easter holiday is to turn our shitty back patio into a nice outdoor dining space (so not much pressure!)
As it's got paving stones down already I've decided on Ikea Runnen clip together decking - there's a small manhole cover in the middle, so proper decking is out.
Space for the Chimnea is sorted, and I've got pallets to build a wood & mower store.
My only decision is what to put over it. Needs to be shower proof and semi-permanent, so a non-pop up metal framed gazebo seems like a good idea. But maybe a bit flimsy?
I haven't got time to build my own wooden structure - this would be preferable, but a lot more hassle.
I've just been looking at the Glendale Seville 3x4m aluminium framed Pergola. Seems decent value at £300ish. Has a fabric roof, and I'd guess I could easily fit some polycarbonate sheets over the top to make it more weather proof.
Any other ideas or suggestions that won't break the bank?
Posted : 09/04/2019 12:10 pm
Heh. You said poo.
Posted : 09/04/2019 12:12 pm
You don’t have an orangery?
Bloody peasants 😉
Posted : 09/04/2019 12:22 pm
Sir! That will neither be a pergola or a gazebo.  A pergola is an arch structure that is usually over a path and so is intended to be walked under/along.  A gazebo is a small separate covered structure, usually round or octagonal in shape, which is intended to be used to give a wider view to the landscape.  I would contend that sir is in fact intending to construct an arbour.
Posted : 09/04/2019 12:29 pm
I built this with my own bare hands for about £500 including the polycarb roof. Really pleased with it and was nice to be able to sit outside in the rain.
Only issue was it became a haven for false widow spiders 🕷
Pergola
Posted : 09/04/2019 12:30 pm
A pergola, arbor or arbour is a garden feature forming a shaded walkway, passageway or sitting area of vertical posts or pillars that usually support cross-beams and a sturdy open lattice, often upon which woody vines are trained. As a type of gazebo, it may also be an extension of a building, or serve as protection for an open terrace or a link between pavilions.
Posted : 09/04/2019 12:34 pm
Heh. You said poo
Yes, yes I did. Managed to get it inside the edit window though.
Stevie's - that looks great. I'm short on time though...wife's at work, and kids are with me. I need something I can assemble in an afternoon or so.
Where did you get the Polycarbonate sheets from?
Whatever I buy, I'll probably want to upgrade the roof with some of those.
Posted : 09/04/2019 3:08 pm
I think it was from the roofing superstore ( https://www.roofingsuperstore.co.uk/browse/roof-sheets/polycarbonate-roofing/twinwall/bronze-twinwall-sheets.html) although it was several years ago now.
Posted : 09/04/2019 3:22 pm
