PC upgrade advice, ...
[Closed] PC upgrade advice, please.
Folks, I'm looking at either replacing or getting my PC upgraded.
I don't suppose I need anything special (interweb, e-mails, photo storage, MS Word docs).
Will this spec from a local shop be ok for an upgrade?
Upgrades:
Upgrade your old tired computer £---*
Dual Core upgrade package, includes:
Intel Pentium G860 Dual Core 3.0GHz 1155 Processor
Main Board: Socket 1155, DDR3 1600, PCI-Express, SATA, VGA,Audio & LAN.
4096MB/4GB High end DDR3 RAM (inc. heat sinks)
Price includes full installation into your original PC case, PC Service, hardware check and software optimisation.
(Other Parts / Components may be require, these are not included in the initial £---, for example, a new power supply unit may be require, this is not covered by the initial £).
Thanks in advance.
Posted : 26/03/2013 12:37 pm
Re-install Windows. No need to upgrade hardware at all. Hardware doesn't get slower with time, Windows does though.
Posted : 26/03/2013 12:39 pm
 mboy
Yes, but how many of the penny will it cost?
To be honest, you may be better off buying a new box from the likes of ebuyer, you could get something that spec for very little money.
Posted : 26/03/2013 12:40 pm
Reinstalling from the recovery partition will cost £0.
Posted : 26/03/2013 12:43 pm
My PC is old, in my system properties it says;
Intel Celeron CPU
430 @ 1.8GHz
1.80GHz, 0.99GB of RAM
I've yet to go down and quiz him about the price.
I did call in about a month ago, he said (& his website said) a whole new PC with similar spec to the upgrade would be £200ish.
Posted : 26/03/2013 12:54 pm
So, if I got someone to re-install Windows, I'd have a whizzy pc?
Posted : 26/03/2013 2:20 pm
If you do a clean wipe and reinstall, it'd be the same as it was when it was new. It's really really easy to do, generally speaking. You just need to back up your files, photos etc.
Caveat - assuming your HD doesn't have loads of bad sectors. This can make it slower, but that means it's about to fail anyway, probably.
Posted : 26/03/2013 2:25 pm
A 1.8 Ghz Celeron will still be a very slow computer even after a reinstall, have a look at eBuyer for a new one.
Posted : 26/03/2013 3:32 pm
Apple Mac. I got pissed off with windows 6 years ago, bought a Mac, no viruses, no down time since. Not a fan of its customisable programs, apps etc. but it works every time.
Posted : 26/03/2013 3:38 pm
Whilst molgrips is correct he is only halfway there.
Your computer will be as new, and will perform as new, ONLY if you're using exactly the same software you were when you bought it.
Which, if you're using the internet, you're not.
As web development has evolved faster and faster websites have ballooned in the number of resources they need from your computer. With the arrival of HTML 5 and the arrival of browser rendered graphics etc it's even more important than ever to have a GPU accelerated computer.
Even on STW I'm seeing 6 animated banners currently - this all requires processing.
So, while it'll run your old software fine, any up-to-date website will cause you to be back in slowville.
So, apologies if that was a bit of an overload, but it's something to help you consider your strategy before you go down the route of formatting and reinstalling only to find out your PC still struggles when you have multiple websites open.
Posted : 26/03/2013 3:47 pm
Apple Mac
Do you get many of those for £200?
Yeah, I was thinking that myself. Ordinarily I'd say chuck some more RAM in it, but you'll still be stuck with that Pantium CPU.
That said; I'd need more info to be 100% sure, but you can probably drop a Prescott vintage P4 straight into your PC. You can pick up a 3GHz chip from eBay for under a fiver (I've just looked). That and another couple of gig, it'll be a different machine. The new one you've specced will still batter it, but it'll be ten times the cost.
Posted : 26/03/2013 3:51 pm
Pentium 4s came in several FSB speeds. You would have to have a good match. Also some BIOSes won't accept a chip they aren't aware of.
http://www.tomshardware.co.uk/forum/81002-35-challenging-problem-tosh-northwood
I'd say get your mate to put together a cheap PC with an AMD APU. An APU is a CPU with a small, but dedicated graphics portion. Only the VERY newest Intel chips have an APU that is even halfway decent. I'd go for AMD in your case, 100%
You may be able to re-use some of your parts. But I'd change the Hard disk even if you don't have to, and the PSU. Keep the PSU as a spare, and use the HDD in a cheap external case - but don't use it to keep files that are not backed up elsewhere.
Regards
Posted : 26/03/2013 4:31 pm
Right, that's me even more confused.
He says about £170 for the upgrade.
I may just get a whole new one. I'll then have a spare to take to pieces & mend.
Posted : 26/03/2013 5:26 pm
Have a look on here.
http://www.ebuyer.com/search?sort=price+ascending&cat=191&store=5&cat=191&page=1
Just make sure it includes the Operating System, as some don't (or whack Ubuntu or Mint on it).
Posted : 26/03/2013 5:38 pm
So how does his CPU compare to say, an Atom?
Posted : 26/03/2013 5:41 pm
That link is for a laptop rather than a desktop but yes, that's a good point. I'd want to check properly what the motherboard supported before making firm recommendations.
There's not a huge amount of difference between the two, the "upgrade" there is practically a full PC apart from, what, hard disk, PSU and a box to put it in.
If you've use for a second PC <cough>backups</cough>, there's an argument for just getting a new system.
Posted : 26/03/2013 5:43 pm
[url= http://www.cpubenchmark.net/cpu_list.php ]CPU Benchmark[/url] is your friend, by the looks of it a 1.8Ghz Celeron is slower than most Atom's
Posted : 26/03/2013 6:28 pm
Sorry..I meant to say non-customizable ie. only the Apple endorsed apps etc..
And unfortunately you can't get one for £200. The cost of it hurt at the time I bought it ( wasn't brave enough to tell the wife ). Not regretted getting one.
Posted : 26/03/2013 6:53 pm
I'd really say your best bet is a new machine built around an AMD chip, like this one
http://www.ebuyer.com/398817-amd-a6-5400k-black-edition-3-6ghz-socket-fm2-4mb-l2-cache-retail-ad540kokhjbox
You'll note there are bundles on that page with a Motherboard. Try to get one with RAM also.
It's not going to be much for £300 or so, but it will be a lot better than your current machine. 4GB of RAM, or more. DO NOT reuse your old HDD or Power Supply, they are the most likely things to go wrong in a PC and also the things that cause the most damage/hassle when they fail!
Use a basic branded PSU, like a Corsair or Antec
[URL] http://www.ebuyer.com/185183-antec-380w-earthwatts-green-psu-ea-380d-green [/URL]
That should do.
Then stick a modern Hard drive, maybe...
[URL] http://www.ebuyer.com/319639-seagate-1tb-barracuda-internal-hard-drive-st1000dm003 [/URL]
These are fast.
Don't skimp on those parts!
Rebuild around that, and for <£300 you'll have a reliable, balanced and reasonably future-ready machine.
Lastly, buy Windows 7 OEM - comes with less packaging, but is cheaper.
[URL] http://www.ebuyer.com/259863-microsoft-windows-7-home-premium-w-sp1-licence-and-media-1-gfc-02050 [/URL]
That's my suggestion. Get the shop to do all the assembly, or your mate!
Posted : 26/03/2013 7:30 pm
I'd second the PSU advice, though 380W seems awfully low to me. (But then, I guess a modern CPU requires a lot less power; I'm a bit out of touch, it's been a while since I last looked at system builds.)
It's an oft-overlooked component and will cause much wailing and gnashing of teeth dealing with ephemeral fartabouty problems if it's underspecced.
Posted : 26/03/2013 7:57 pm
Thanks for all the advice, folks. I've got to start googling now, trying to understand what you're all on about. 😉
Posted : 26/03/2013 8:49 pm
Non-technical version: buy a computer.
Posted : 26/03/2013 8:51 pm
I thought that's what it meant.
Posted : 26/03/2013 8:55 pm
 mboy
Yup, just buy a new one. Not worth messing about using any 8yr old components in a mish mash of new parts. If its all new, and comes with a warranty (even if only covering the hardware), its added peace of mind. For £150 (excluding an OS) you can get a new machine that will have 10x the computing power of your current machine. You can get a copy of Windows for less than £70, so its a no brained in my mind. In fact, in your situation, I'd throw a bit more money at the situation, to make sure the machine is more future proof. A £150 box now will be comparatively slow in 3 years, spend £400 on an i5 machine with 8GB of RAM and windows pre installed, and it'll still serve you well in 5 or 6 years time at least.
As for the suggestion to buy a Mac. Much as I love Apple's OSX, and many of their machines (lack of upgradability on some is a bit poor mind), its a bit like taking a sledgehammer to crack a walnut given the OP's requirements. If you're a graphics professional, or musician, a publisher or even just have a load of cash burning a hole in your pocket, go out and get one, you won't regret it. But even a basic Mac Mini at £499 would be overkill for the OP's requirements.
Posted : 26/03/2013 9:42 pm
Agreed on all counts.
I view Mac suggestions like that as Apple Tourette's. Pick any tech-related topic, someone will just blurt out "get an iPhone" or similar, irrespective of whether it's an appropriate recommendation or not. Sometimes it's a very valid suggestion, but often it just appears to be some sort of nervous twitch.
Posted : 26/03/2013 9:52 pm
if the OP was more tech savvy I'd say "get a hackintosh" but that's just because I'm a windows 7 hater.
Instead of splashing out on a upgraded desktop I wonder if the OP has considered a laptop or a tablet? Might be a better experience for the casual user. The old desktop will make a pretty serviceable word processor especially with a fresh windows re-install.
Posted : 27/03/2013 6:49 pm
But you can't re-install it on another machine if yours dies or you want to upgrade.
Posted : 27/03/2013 7:09 pm
This.
If you buy the retail version of windows, you can install it onto a new machine. Also, if you upgrade your Motherboard in the future, you won't need to purchase another copy.
Posted : 27/03/2013 8:08 pm
"Can't" isn't strictly true. "Not allowed" is more accurate.
Posted : 27/03/2013 8:10 pm
I thought it was a bit of a techie fiddle to get it to work on a new machine?
Posted : 27/03/2013 8:15 pm
IIRC, you can re-activate the key three times and then it's a 'ring Microsoft' job. "I've just replaced the motherboard" should suffice as an excuse.
Probably. Obviously I'd never advocate that and have never done it. Obviously.
Posted : 27/03/2013 8:19 pm
ok, notwithstanding the above, i'd recommend you buy a proper retail version of Windows!
Has anyone mentioned that Linux can work fantastically well on older machines...? 😉
Posted : 27/03/2013 8:54 pm
Huuuuummm.....
I didn't know that. Guess I've not changed any "important" parts on the machines I built. Gigabyte Motherboards FTW!
Thanks for the tip!
Posted : 28/03/2013 8:34 am
Thanks for the input, folks. (GFS, I've got a Gigabyte Motherboard box kicking about with driver cd roms in, so it looks like that's what this old machine might have in it).
I've decided to go get a whole new pc, though I'll just go to PC World in town to get it, right there & then (I can't do with the suspense of waiting over the weekend 😉 )
I'll then have an old pc that I can take to pieces and "mend". 🙄
Thanks again.
Posted : 28/03/2013 8:53 am
Much as it is tempting to trundle down to PC World for a new computer it is most likely that you will not be getting the best value or best machine for your money. As others have pointed out good places to look for pre-built machines that will almost certainly be better spec and value include Ebuyer, dabs, scan, novatech.
Posted : 28/03/2013 9:13 am
I concur with Bikingcatastrophe.
Posted : 28/03/2013 10:01 am
Scan's "Today only" page is worth a browse, there's often some belting deals to be had.
Posted : 28/03/2013 10:25 am
 nbt
I just ordered one of these
http://www.ebuyer.com/407538-zoostorm-desktop-pc-7873-1076
£150 for a PC that will be fine for browsing, watching youtube videos and viewing photos.
I have a legit copy of windows to install but as has been pointed out you can get OEM copies from ebuyer for about £70
Posted : 28/03/2013 10:31 am
Have you asked around the pc shops near you for second hand? Something that's being thrown out could easily have better spec and be able to run W7.
I just picked up an old case for free with a Celeron D 2.6 in it and it runs W7 well enough.
Posted : 28/03/2013 12:56 pm
IU wouldn't pay a shop to do that upgrade in the opening post unless they are charging less than £100. It's something you can easily do yourself. There is no technical skill needed, just follow instructions
Posted : 28/03/2013 1:47 pm
[URL] http://www.dansdata.com/sbs3.htm [/URL]
These instructions?
Posted : 28/03/2013 1:56 pm
