Osram Nightbreaker/...
[Closed] Osram Nightbreaker/Philips Xtreme Vision etc., car bulbs...
...are they really any better than the bog standard H7 Lucas bulbs I can get from the motor spares place at a third of the price?
Posted : 08/02/2018 11:40 am
Night breakers made a huge difference on what ever I've fitted to then .
That is to say fireflies in jam jars would have been improvement over previous bulbs.
Posted : 08/02/2018 11:43 am
Yes, I've had +50%, +100% and now plus 130%, I honestly assumed it was marketing boswollocks but each time it's been an improvement.
Posted : 08/02/2018 11:45 am
 P20
Yes. Normally use Ring Xenon 130, but the Philips 150% were a good price on amazon. Normally find ring offer the best balance of life v brightness.
Posted : 08/02/2018 11:57 am
Yes. I put them on just the dipped beam (as I ordered the wrong bulbs for the main by accident initially), and the difference side by side was quite impressive.
They were +120%.
Posted : 08/02/2018 11:58 am
Please bear in mind that some non-standard bulbs may change the pattern of light from your headlights, thus dazzling other drivers, or may draw too much current for your cards wiring.
Not to say they can't be a good thing, but just to bear it in mind...
Posted : 08/02/2018 12:00 pm
I've just replaced both the dip beams on Mrs Davesport's shopping trolley XC70. The marketing bollocks stated 130% more light, so it's fair to say I was expecting double the light. Id put the improvement about 20%, it's definitely an improvement but not massive.
Posted : 08/02/2018 12:05 pm
They made an improvement to the piss poor headlights on my honda accord, but then again attaching a couple of birthday candles would also have made a difference.  They were still pish, just not as pish.  They won't make crap headlights into great headlights.
I solved the problem by buying a new car with bixenon headlights, **** me I can actually see 🙂
Personal experience with Philips is they don't last long and end up looking the same after a couple of months (ended up with the old Osram side by side).
Posted : 08/02/2018 12:10 pm
I had some Nightbreakers. They were very good while they lasted. One went pop after 5 months, prior to that, the bog standard bulbs were fine w.r.t life.
The LED's I have now are another level, though. And cheaper.
Posted : 08/02/2018 12:35 pm
are they legal LEDS ? how are they in the wet ?
Posted : 08/02/2018 12:41 pm
I've had the Ring +130 H7 (dipped) in both my Mundane-o and the Mrs's Golf for about 6 months now. In both, it's a significant improvement over the stock bulb.
NB twice as much light doesn't mean you can see twice as far, unfortunately.
They are noticeably better. I'll settle for that.
Posted : 08/02/2018 12:50 pm
I've used the Philips Extreme and Osram Nightbreaker in H4, H1 and H7 variations. They transform poor headlights to good and good to great. They only last me a year or so but are worth the money for the increased light output in my mind.
Posted : 08/02/2018 12:56 pm
Yes they are brighter, but IME they last a year and go pop.
I am back to boggo motor factor bulbs, at £1.99 each.
Posted : 08/02/2018 12:57 pm
I read the thread title as 'Night Beaker' and thought this was going to be another mums net thread!!
Posted : 08/02/2018 1:15 pm
Ive put 80w off road bulbs in my old V70, it's better than before.
Posted : 08/02/2018 2:03 pm
 P20
Just had a look at the price on autobulbsdirect of the led bulbs 😲. Not road legal either
Posted : 08/02/2018 3:06 pm
I’ve had them on the motorbike for ages. Yes there’s a vision improvement but only to the point where they go pop. Then you have to ride around with high beam on until you get home......
They don’t last long enough IME. A year tops.
Posted : 08/02/2018 3:20 pm
Overheard the mechanic at the local garage yesterday  saying they were failing quite a few cars for incorrect headlight bulbs recently.
Posted : 08/02/2018 4:34 pm
Dickyboy
Member
Not for Osram Nightbreakers they weren't. Aftermarket LEDS or HIDs maybe.
Posted : 08/02/2018 4:41 pm
I read the thread title and thought it was going to be another Marvel character.
NIGHTBREAKER....Light up that roadkill,,Arggghhhhh >smiley face<
Posted : 08/02/2018 4:44 pm
... oncoming drivers wincing and squinting into my stupid-bright dips ??
It's an arms race akin to the mtb nightride lumen wars - once some cock dreamt up the full-intensity dipped light we were always heading only one way
Posted : 08/02/2018 5:54 pm
MOT rules are changing in May 2018 so that HID bulbs fitted to headlamps desgned for halogen bulbs will be a fail. I'm glad I only spent £35 on the HID kit fitted to my car. I'll be fitting Nightbreaker Laser bulbs this weekend.
Posted : 08/02/2018 11:01 pm
I’ve just this evening bought some GE megalight ultra 130 for my old mans Passat. I’ve had nightbreakers, racing vision, xtremevision and a couple of other ‘high performance’ type bulbs in it over the years. They’ve all been an improvement, I generally go on whatever does best in each years auto tests. This year it’s the GE’s.
Ive found they do dim over time and see them as a consumable. I change them out before they go and stick one of the old ones in the glove box in the box the new ones come in just in case.
I bought the GEs from powerbulbs.com, they’ve got a 20% off offer using 20FEB as the code. I was going to buy them anyway so that was a nice coincidence.
Posted : 08/02/2018 11:44 pm
Will fitting brighter bulbs stop me being blinded by oncoming traffic or is the objective to blind them back?
Posted : 09/02/2018 7:20 am
kelron, it does help a bit with oncoming traffic in that you can still see a little bit more of the area in front of you
blinding them back - that's what I was saying up there about nightrides; you can't have brighter lights and not affect other users.  If (big if) they're well set on dip then it's OK on a flat smooth road but hitting a bump or cresting a rise and you'll definitely affect oncomng drivers more
Posted : 09/02/2018 7:40 am
