Sorry this is a bit random but one of you may be able to help me
I am trying to source some brackets like this u shaped bracket under the bench cushion. It supports a fold down bed edge so needs to be stronger than a standard closet bracket.
Does this type of bracket have a specific name? Do you know where I can buy something similar off the shelf? I am sure I could make something but it will look a dogs dinner and take me ages!
Many thanks
I'd try looking at the sort of shops that do camper, boat or narrow boat furniture... that might lead you in the right direction? Good luck.
UHPPOTE Oval Closet Rod End Support for 15x30mm Rods (2 Pack) From Amazon?
Forget closets, "Bed rail fasteners" or "Bed rail brackets" is what you're after.
https://www.amazon.co.uk/s?k=bed+rail+fastener&i=diy&ref=nb_sb_noss_2
Also "Sectional Furniture Connector"
Thanks for the 3 trying to help with my challenge. MLC looks like he has set me on the right track by challenging my closet bracket strength concern. However I am not sure about a metal bracket as you could catch your leg on it when in the seated position.
I was hoping someone could come up with oh you need to look at these guys they make loads of cheap teak standard components - moon on a stick i guess!
thanks for your help anyway but guess I am going to have to try and make something. Do you think it could be made on a 3D printer? Not that I have any idea about these either!
thanks
Way-Hey, 1980s boat upholstery ๐ Thats a familiar pattern.
