One tyre, two tyres...
[Closed] One tyre, two tyres, and/or winter tyres?
BMW 330i. Puncture forced the replacement of one rear (a 255) the other is now at the limit. Do I replace with one and perpetuate the mis match tyres issue, or both and "waste" half a tyre?
And while I'm at it I'm doing 10k miles a year 3/4 is motorway - is it worth considering winter tyres whilst I'm doing so? I've not read the lengthy threads on here about the subject, but "get" that there might be benefits particularly for a 3l RWD.... Although the info on Blackcircles isn't favourable with regard to fuel economy....
Posted : 28/06/2014 9:46 am
Winter tyres depend massively on where you live and if you can survive without a car for a couple of days. I have some winter tyres and on the odd snowy day they've been dead useful. Ultimately though I don't think I'll be replacing them. However if your livelihood depends on being able to motor every day of the year then yes they're great.
[u]Positives[/u]
+ I can get into work on snowy days
[u]Negatives[/u]
- I've probably spend more on winter tyres than I would have if I had taken a days leave
- I can now work from home so probably won't be replacing them
- Even when they have been of use when snowing there are still lots of muppets out there abandoning their cars and blocking the roads.
Posted : 28/06/2014 9:56 am
Winter tyres if you drive the majority of the miles in Jan and Feb below 7 degrees. Normal tyres if your drive mainly in warmer weather ie + 7 degrees.
Last year the temp rarely went below 7 degrees in Yorkshire.
Also if you go winter tyres you will really need to do all 4, plus the fact they are more dangerous + 7 degrees
Ive got a BMW, and for those 3 days a year it may help Im going to get some snow socks and leave them in the boot.
Posted : 28/06/2014 9:59 am
Normal tyres it is then cheers.
Posted : 28/06/2014 10:14 am
