numpty tennis quest...
[Closed] numpty tennis question
 iolo
Why are players given 3 balls to play?
1 is always thrown to to ball person so why not give them 2?
Posted : 26/06/2014 2:40 pm
They like to choose which ones they are going to serve with. Sometimes they'll take more, if more are available. There are i think 6 balls in circulation at any time.
I don't know what they look for, mind.
Posted : 26/06/2014 2:43 pm
Tis the magic number.
Posted : 26/06/2014 2:45 pm
Simply to give the player serving an opportunity to choose what they see as the best 2 balls.
They will usually give them a quick check for damage or marks that may affect the balls flight. This is also why they regularly change the balls.
I imagine a lot of the players will also do it as part of a routine to help with focus. You will also notice that some players do the same by asking for a towel, either as a brief pause to re-focus or a tactic to delay the opponent.
Posted : 26/06/2014 2:48 pm
I worked with an ex-pro player. His take on it was, the more a ball gets hit the softer it becomes, the slower it travels. They try to choose the freshest balls to serve with.
^^^^^As above really.
Posted : 26/06/2014 2:59 pm
cause everyone likes to play with balls...
IGMC
Posted : 26/06/2014 3:02 pm
There's far too much pissing about between points these days. What with looking at every ball and having a little towel down after each rally over 5 shots. Back when I were playing you'd **** the first ball with another in ya pocket. First serve in then request another.
Posted : 26/06/2014 4:04 pm
when I were playing
Championship level, was it?
Posted : 26/06/2014 4:07 pm
Its so they can pick the freshest ball for the first serve. The less the surface is roughed up the faster it will travel. TBH I can't see it making much difference give they get new balls every seven games.
It does make a noticeable difference when you don't get new balls that often - when I played I used to pick a newer ball for fast flat first serve and then and older scuffier one for second serve which I put a lot of spin on.
I agree - way too much fannying about between points. And can someone please get Rapha some shorts that fit - he's forever pulling them out of his crack.
Posted : 26/06/2014 4:12 pm
