I thought it may have something to do with the density of the nut, increased moisture content in the unopened shell- i usually grab the bags at the top corner and give them a shake as that gets all the nut detritus to fall in the bottom corner, along with our heavier, uncracked pistachio. That explains it then - well done stw. The increased moisture content will also explain the rather foul taste of the nuts , that's if you actually manage to open them without the aid of a Leatherman to hand - it's pointless to eat them as they more often than not taste bitter and spoil the happy thoughts of the previous 30min scoffing session
Driving past Cromarty Firth a couple days ago has added a new one. Oil/Gas platforms stored 'in land'
The fact that in the Netherlands its normal to rent a flat....and not have it come with a floor, or light fittings.... Because they're something you take with you when you move (how the actual faaark am I supposed to move in when it's sodding dark??!)
Well you can look forward to the fact that when you move out you will have to pay to restore the place to the same state it was in when you moved in i.e. fresh paint etc., despite the fact that you've lived there for years and paid a sh1t load of rent.
Gravity waves, space time and all that. So much left to discover.
online forms that use a different format to the reference number on the paper form that you are entering the details from - you've printed it with spaces so I stupidly assume that is the format and I'll know it'll become obvious quickly when I run out of space or slowly and painfully when I hit send and am told there is an error on the page and half the other st!te needs to be reentered while I'm still guessing how to format your sOdding reference
