Netflix help - Jitt...
[Closed] Netflix help - Jittery play back on TV
Signed up for Netflix the other day, very happy with the content.
Playback through the laptop screen is fine.
However, when connected to a large TV with HDMI, it gives a "jittery" playback.
I googled the problem and was advised to reduce the buffering rate for Silverlight, this gave an improvement but there is still a slight "jitter."
The laptop is HP Pavillion dv6, 1.8ghz quad core, 6 GB ram. AMD onboard graphics with 512mb ram but with 3 gb available according to Windows.
There is no option to adjust the memory used for video in the BIOS.
I would of thought the laptop is up to the job.
Any suggestions?
Posted : 27/03/2014 9:19 am
Try reducing the res on the TV and see if that helps.
Are you using the same quality of video in both applications?
Posted : 27/03/2014 9:58 am
I'll drop the TV to 720p and see if that helps.
The only choice on netflix is HD on or off, not sure what the output actually is.
Posted : 27/03/2014 10:00 am
Chromecast, if your TV has got a USB port?
Posted : 27/03/2014 10:18 am
Possibly conflict between frame rate on laptop output and tv settings?
 IA
Could be this, what refresh rate you driving the TV at?
Posted : 27/03/2014 10:22 am
Thanks for all the help gents.
Just had a look at my options in the set up.
There is no option to change the resolution or frame rate I can see in the menu. It is all auto detect from the source.
I know it shows the resolution when I change source and it shows 25fps when playing blu ray, but it's all controlled automatically.
Any suggestions?
It's a Panasonic Plasma.
Posted : 27/03/2014 10:44 am
What's your broadband speed like? Most of my netflix problems come from poor broadband speed
Posted : 27/03/2014 11:08 am
Mine too. What's weird is that I constantly have problems with the WiFi connection from my TV to the router, but next to none if I use AppleTV instead.
Posted : 27/03/2014 11:13 am
Broadband speed is excellent. I get 40 mbs at times but generally around 25 mbs.
Wifi "N" connection and not sharing it with any other machines at the time.
Posted : 27/03/2014 11:27 am
Are you driving the TV in addition to the laptop screen? If so, don't do that.
Posted : 27/03/2014 11:39 am
No, selected "Projector Only".
Posted : 27/03/2014 11:41 am
 IA
No, I mean on the laptop - what's the refresh rate set to?
Try setting it lower, 24/25 perhaps, or 30.
Posted : 27/03/2014 11:42 am
+ 1 for the Chromecast option. Works a treat 🙂
Posted : 27/03/2014 4:44 pm
Netflix streams in 720p, I have the same problem on my big tv. If your sharing hdmi to micro hdmi or usb it tends to suck. I'd flash back one of those smart tv £10 boxes if I could be arsed. Also watching through an xbox or ps3 will work great.
Posted : 27/03/2014 6:25 pm
no it doesn't - it streams up to 1080P, or Super HD as they call it.
Posted : 27/03/2014 7:16 pm
Thanks IA. Dropped it to 25hz and it looks fine. Result!
Posted : 27/03/2014 9:41 pm
In my experience (all with Apple kit) the jittery playback is always down to broadband signal. I don't stream much anymore as a result I prefer to download first and watch later, eg iTunes rentals or BBC iPlayer.
Posted : 27/03/2014 9:59 pm
Does setting the refresh rate lower on the laptop reduce the download needs, i.e. lower refresh means less pressure on broadband connection ?
Posted : 27/03/2014 10:48 pm
There is no problem with my broadband speed, it's BT Infinity and normally runs at around 25 - 30mbs.
Dropping the frequency fixed the problem.
Posted : 28/03/2014 9:42 am
Refresh rate affects the graphics card and the way it displays images. Nothing to do with network.
Posted : 28/03/2014 9:44 am
I'd be surprised if there is no way at all to set the refresh rate on the TV for the input you're using, and also surprised if 25hz is the best option all round. I would guess that your TV is on 50hz and you should be able to set the laptop output also to 50hz. Glad it's working better, anyway.
Posted : 28/03/2014 9:52 am
 IA
I suggested that as most content is 24/25fps natively, so no point displaying twice the framerate (and working the graphics card twice as hard), and the tv will be designed to work well with 24/25hz input over HDMI.
Posted : 28/03/2014 10:39 am
Yep noted, and as I say glad it's working. I'm still surprised, though! 🙂
Posted : 28/03/2014 12:43 pm
