No its not for drugs- are they available on the high street?
Pends what you need them for. You can buy insulin needles in chemists I think. A needle exchange will give you a few without any questions but that's a badly needed resource that's probbly underfunded anyway so don't take the piss.
Syringes are easily available, but what do you need the needles for? Terrorist purposes? Injecting fruit in supermarkets with deadly poison?
Go to your local doctors surgery. If its medikit for overseas travel you can order these
need them to inject white sprits into a grip to help remove it. all i need is one. is the parmacy at e.g. tescos likely to have them?
Eh? Are you mad? Just use a thin screwdriver and spray WD40 or GT85 in using the little straw.
I suspect this is merely subterfuge, and that really you are a terrorist. The 'need to get my grips off' story is weak. I saw through it immediately. You can't get anything past me, sunshine...
foiled!
In all srriousness, it is for removing golf grips, so the screwdriver technique doesnt work im afriad
Oh here you go, trying to change the story. Well, that's not going to work on me, sorry.
People like you [i]disgust[/i] me.
'Golf grips' indeed... ๐
I'm off to grass you up to MI5....
Golf....! thats wrong. Go to the pub and erase such a sport from your memory with copious amounts of beer
Got one from ebay
cut them off? Or failing that SP services on that interweb malarky will sell you pretty much anything
If your not going to use it to inject drugs, a quick read of the daily mail seems to suggest that there are loads of used ones littering any childrens playground, Careful tho.
sport
[url= http://www.freesmileys.org/smileys/smiley-forum/rotfl.gi f" target="_blank">http://www.freesmileys.org/smileys/smiley-forum/rotfl.gi f"/> [/img][/url]
It's probably more acceptable to admit to being a terrorist or a drug addict on here than it is to admit to being a golfer.
Pump them off.
Hold the nozzle of yout track pump over the hole on the top, get an assistant to operate pump, hold the bottom of the grip tightly to keep the air ina and pull the grip upwards. It'll be like it's wee hovercraft.
seriously though can't you get them for free? Ask in a chemist for the swap back, use the needles and bin the rest???
bigM, sounds interesting- i thought you needed compressed air to do that. could you elaborate?
And rightly so! ๐ก
You can get them very cheaply from the vets. I bought some big ones for brake bleeding duty.
you can get them for free from a pharmasist, you might have to sign a needle exchange form. I got two for bleeding brakes over the counter with no hassle.
loads on ebay
