My fire rope has co...
[Closed] My fire rope has come loose at the bottom. Will I die?
As above. I've not got time to replace it till Sunday but I don't want to harm the family. We had an open fire before so I assume we are safe but I thought I'd check.
I presume the real problem is that without a seal we can't control the flow of air in.
On the subject of fire rope, everything I've read says 14mm for my Stovax Stockton 5 but the new rope looks very fat.
Posted : 08/11/2012 8:27 am
Yes, you will die.
Posted : 08/11/2012 9:31 am
Yes horribly, I'm watching you now!
Posted : 08/11/2012 10:09 am
Almost certainly but not from that. Most stoves I've had have had rope hanging off them at some point.
Posted : 08/11/2012 10:10 am
Aaaaaaaaaaah!
Posted : 08/11/2012 10:16 am
Just checking, my little boy has been poorly all week so I wanted to rule that out. Thanks Mike ๐Ÿ™‚
Posted : 08/11/2012 10:18 am
what does a fire rope do?
I've seen gas fires spilling CO due to them not being sealed correctly, either into the opening, or the surround not being sealed. You can get the flue pulling via these unsealed bits rather than from the appliance itself.
Just a thought
Posted : 08/11/2012 10:22 am
It acts as the gasket that seals the door of your stove as you close it.
Posted : 08/11/2012 10:48 am
