Muvi DV Micro came...
[Closed] Muvi DV Micro cameras or what ever they are called
The little £15 video jobbies, how do you set the time and date ?
mine is stuck in 2008 !!
likie this one http://www.7dayshop.com/catalog/product_info.php?cPath=777_1&products_id=109557&PHPSESSID=bdeofl2vcp1f1afsa46ui5cjo0
Andy
Posted : 10/09/2010 6:57 pm
This is all i have to go on and not being a computer nerd i seem to be having no joy 🙁
""There is a CD with the product which contains a file named time synchronization file. Please copy it to TF card. When connect D001 with computer, whose time will be displayed with computer synchronously.
The detail as following:
1. build a text called TAG.TXT under root directory of card.
2. open TAG.TXT,write synchronous date according to enclosure stricktly.
Details as following:
[date] need space with newline
2009/07/22 need space with newline
12?00?00
Power on the machine everytime, system will check and analyse TAG.TXT, then set system time according to file time. After that the text will be deleted by system automatically.""
Posted : 10/09/2010 7:26 pm
well bugga i seem to have sussed it
just forgot to turn it off then when it fired up again the time was sorted
Posted : 10/09/2010 7:31 pm
