Motorhome/caravan D...
[Closed] Motorhome/caravan DIYists; A question...
I have removed my gas locker door. Completely. The frame and everything. This was due to a seized hinge. I am replacing the hinge, and then will want to reinstall the door frame into the cut-out on the van. Previously some kind of mastic was used, but I was thinking of using some kind of adhesive/sealer, like Sikaflex 512.
I read recommendations of Soudhal (sp?) Fix All, and today the guy in the shop (hardware) suggested "Sticks Like Sh*t".
I am a bit concerned that using this kind of stuff may mean it is IMPOSSIBLE to remove the frame ever in the future, but the mastic seems so feeble...
Any thoughts..?
Posted : 09/12/2013 7:31 pm
Blimey.. I just go to B&Q and get whatever looks good ๐Ÿ™‚
Posted : 09/12/2013 7:53 pm
You need something with a bit of give, or it'll rattle itself loose. That's why Sika[b]flex[/b] is recommended.
Posted : 09/12/2013 8:08 pm
Sikaflex is the stuff for caravans and motorhomes
Posted : 09/12/2013 8:26 pm
+1 for Sikaflex
Posted : 09/12/2013 8:28 pm
I love Sikaflex. Mind you, I love all dubstep
Posted : 09/12/2013 8:35 pm
You are right if you use an adhesive sealer like SikaFlex 512 or PU 40 it will be a pretty permanent bond that would be very difficult to remove. More likely to damage the frame or panel. But you should get a good strong flexible water tight seal.
The non-setting mastic type sealers are recommended for thie type of application. Some thing like Seamseal CV or BR.
http://www.hodgsonsealants.com/product/10164/seamseal-cv-380ml-x-24
http://www.hodgsonsealants.com/product/10163/seamseal-br-380ml-x-24
The drawback of these is they can dry out and crack after a number of years, which can lead to some water ingress. However at least you can get the frame out to clean up and reseal.
Posted : 09/12/2013 9:01 pm
Mark90 seems to understand my dilemma.
Posted : 09/12/2013 10:28 pm
If you want it to stay flexible and come off again later cleanly then you can get rolls of butyl strip on ebay - like a super-sticky blutak already piped into a bead.
Posted : 10/12/2013 12:46 am
