Moon landing conspi...
[Closed] Moon landing conspiracy theorists and science educational attainment.
Still doesn’t change the fact that thrust vectoring is thrust vectoring.
I can thrust vector my car exhaust to provide more or less downforce as required but that doesn't mean I can successfully build a vtol aircraft to fulfil a complex mission profile, at a price that suits the government of the day and meets the prevailing wants of the air force procurement staff at the time.
The point I’m making is they had most of the tech and knowledge and then didn’t take the next step, as most seem to be saying the jet version is harder. Had they done a us harrier the lander would have been better, no?
They made a jet/rocket version, as someone else has linked to, the LLRV. Taking test rig technology and turning it into a working combat aircraft is not a simple matter. And no, there is probably not that much that doing one would have improved the other. Some technology transfer, maybe, but as has been said several times before, these are very different problems. Air breathing engine vs rocket, very different atmospheres and gravity, very different tasks to perform.
do you think the us was unable to generate enough thrust with a jet engine or was it the transition as wobbiscott suggested?
They did have some versions over the years that almost got it, see XV4, XFV12 for examples. As did the French and the Russians, Mirage IIIV and Yak 38 as examples. Basically, VTOL is a really hard thing to do well enough to work for a combat aircraft. Making a VTOL aircraft is not the hard part so much as making a VTOL aircraft the is useful in combat. The harrier just happened to be one that hit the sweet spot.
Posted : 31/05/2018 5:42 pm
Your car exhaust isn’t designed for vtol though.
So you are saying that overcoming gravity and slowing forward momentum whist maintaining stability is harder than doing it in low gravity and having to thrust vector in nearly all directions to maintain stability in controlled descent?
Posted : 31/05/2018 5:48 pm
Neither was the Lunar Module.  Your misconception is that is doing the the same job as a Harrier
Posted : 31/05/2018 6:01 pm
I see, what was it designed for?
Posted : 31/05/2018 6:02 pm
Thrust vectoring is thrust vectoring though, right?
Posted : 31/05/2018 6:17 pm
Very good, do you have an answer for my question?
Posted : 31/05/2018 6:21 pm
Which one? Seriously though, I'm struggling to work out what you;re getting at- you've posited that being able to do thrust vectoring/steering of a vertically landing vehicle of some sort in one particular set of circumstances must have some relevance to doing the same with a completely different vehicle in a completely different set of circumstances. Many people have given you answers as to why the two scenarios are very different problems. I gave you an (admittedly silly) example of the extreme of your statement that 'thrust vectoring is thrust vectoring' to highlight what an odd point it is and yet as far as I can tell you're asking the same question of 'why is it different' again, with no attention paid to the answers people have already given you.
Posted : 31/05/2018 6:26 pm
The lunar landing module isn't a V/STOL aircraft. It was designed to decay orbit around a low gravity rock until it literally bumped into it. It was 'controlled' in the sense that they could (slightly) adjust the speed and direction "a bit" but it's not an "aircraft" in any sense of the word. There really wasn't much to actually design, it mostly relies on physics.
Posted : 31/05/2018 6:33 pm
If you can’t explain something simply, so that anyone can understand the basics as a starting point for them you don’t understand the subject as well as you think.
Ironically, it's not that simple.  No matter how good a barman you might be, you can't pour a pint into a half pint pot.
Posted : 31/05/2018 6:35 pm
Swanny, 8 posts up I asked which you thought was harder.
so nick you are sayingin relation to that question, that it is easier to control an object to perform vertical movement on the moon?
Posted : 31/05/2018 6:37 pm
OK. Honestly? I don't know. They are really different problems. If I was going to go out on a limb I'd say that the systems level engineering to make the harrier work as a combat aircraft (as opposed to just making a flying engine) might have been trickier, but that's probably because I understand it better. It might equally be that (made up example alert) they solved a load of intricate technology problems around making extra lightweight rocket nozzles for the lander. They are really different problems.
If you're then going to make a statement of 'well, they could do one why didn't they do the other' then it's rather missing the point.
Posted : 31/05/2018 6:44 pm
Thanks
Posted : 31/05/2018 6:52 pm
It was the US Marines that wanted the Harrier. Not the Army or Navy.
It was not popular with others as they wanted "proper" fast jets. The Navy didn't want little carriers, they wanted, massive Super Carriers, which the Harrier doesn't need but F15s do.
It was more the lack of political interest in developing something that could be seen as a threat to their "core business".
Also, any VTOL aircraft is a compromise, why compromise if you don't need to?
It wasn't any lack of engineering capability that stopped the US from building their own.
Posted : 31/05/2018 7:14 pm
I’m not sure whether to be flattered or insulted
@kryton
Neither really, certainly not an insult.. I think I know your online persona well enough to never make such a judgement.
Just (from my point of view) a little odd comment you made regarding the tech and lack of progression. Working in that vast industry I wouldn’t have though those thoughts would have even entered your mind. Good to have a different POV though.
FWIW I believe the human race either had assistance from Aliens, or there were a few transported here by accident and passed on thier knowledge and skills and thereby the human race developed far quicker that we would have if left alone. Obvs I’ve no proof when/if/why nor how, but there was a giant leap in human development from early man to the age where we made tools etc.
Posted : 31/05/2018 7:21 pm
I understand all of that gobuchul, it just seems strange that the us didn’t do it in house for a major division of its military.
cougar, you can pour 1 pint into a 1/2 pint glass, the customer needs to drink it in two easier to swallow measures.
Posted : 31/05/2018 7:22 pm
Dance, little monkeys, dance!
Posted : 31/05/2018 7:32 pm
The bigger question is why did people not notice the moon people landing here first. Makes you think
Posted : 31/05/2018 7:35 pm
Fly my pretties!
Posted : 31/05/2018 7:36 pm
The moon people got a cloaking device from the Klingons. Because they couldn’t develop their own from low visibility space ship paint.
I think too many kids give up any kind of education in the sciences too early.
Posted : 31/05/2018 7:37 pm
If you’re then going to make a statement of ‘well, they could do one why didn’t they do the other’ then it’s rather missing the point.
The other thing here is that this is possibly a false premise.  @bsims' original question IIRC was something like "why did the US have to buy the Harrier, why couldn't they just make their own?"  It's entirely possible - likely even - that they could have made their own with sufficient investment into research & development and manufacturing.  But why bother if they could just pick up the phone to Hawker Siddey and go, "yeah, it's America here, could we buy a hundred of your planes please?  Love and kisses kkthxbi."
They gave up on grammer too.
Posted : 31/05/2018 7:39 pm
Stop feeding the attention whore,and the thread will die a nice peaceful death.
Posted : 31/05/2018 7:41 pm
bsims
This is like a discussion about how many angels can dance on the head of a pin.
There are pretty well defined documents and popular biographies explaining the invention of the engine which was the heart of the Harrier. It was invented and developed in the UK and was a unique solution to a previously intractable problem.
I answered your original question which implied that the US couldn't have developed a vertical landing system by showing you pictures and video  of the vertical landing system they invented.
Now you've changed the thrust of the conversation to a discussion of why the Harrier was bought and the engineering difficulties of disparate unrelated systems.
Why don't you:
a) Decide what historical fact confuses you the most.
b) Clearly articulate a question that people can answer.
c) Stop moving the goalposts like a big trolly troll.
Posted : 31/05/2018 7:42 pm
... which is precisely the problem.  The customer ain't doing no drinking, he's just sitting there asking for more beer.
You're asking the same questions over and over from a basis of incorrect assumptions and then ignoring the explanations that myself and many others have given you.  If you didn't learn "one of these things is not like the others" from Sesame Street then it's difficult to know what else to tell you.
https://xkcd.com/1133/
Posted : 31/05/2018 7:44 pm
Now you’ve changed the thrust of the conversation
I like what you did there.
Posted : 31/05/2018 7:45 pm
 poah
No but I have lots of experience proof reading science and social science PHDs,
yet you constantly write it as PHD rather than the correct PhD lol
Posted : 31/05/2018 7:46 pm
 poah
bsims
<div class="bbp-author-role">
<div>Member</div>
</div>
<div class="bbp-reply-content">
</div>
cost
Posted : 31/05/2018 7:47 pm
Eat the pudding, the main point was always why they bought it, not that they couldn't make a lander.
Thanks for everyone's opinions.
Posted : 31/05/2018 8:02 pm
And back under the bridge.
Posted : 31/05/2018 8:05 pm
Cool come back, my thanks were genuine to the people who took the time to post detailed replies.
Posted : 31/05/2018 8:08 pm
Quite a few by the looks of it.
Posted : 31/05/2018 8:12 pm
I don't think anyone is saying the US couldn't have developed their own version of the Harrier, they just chose not to. Party, I would guess, because it was used by a small part of the US armed service. They bought a few hundred. That sounds a lot, but at the same time they were buying over 5000 F4's and 1000's of other types.
Why spend time and money for such a small requirement.
Posted : 31/05/2018 8:16 pm
I have read the sr 71 was signed off accidentally by Congress ( who thought they were getting a different plane) which if actually true shows how much money was available to defence projects.
But the SR-71 was not a defence project! It was built for the CIA, and flown by spooks, the whole thing was paid for by off-the-books funding and built by Lockheed’s Skunk Works, they had to develop entire new engineering and manufacturing technology in order to actually make the bloody thing, because they were using a metal that had never been used before, titanium, and had to work out how to make the tools in order to work the material before they could make the airframe, an airframe that had to function at very high temperatures, which meant it had to expand, which meant the full tanks leaked like a sieve while on the ground, but the engines were designed to burn a fuel that would not ignite when exposed to a naked flame. It was only later when the Air Force found out about the plane that they started chucking their toys out of the pram and demanded their share of this whizzy new toy to play with. The SR-71 was a truly extraordinary aircraft, unmatched in its performance, and unlikely to be equalled. There was even an attempt to build a fighter version, the YF-12A, sort of hyper-Lightning, but the bloody thing was just too fast, a turn started over London took it out over Paris before coming back over London. If you can find a copy, there’s a book that covers the development, called ‘Skunk Works’, which is about the history of the place, and the amazing man responsible for designing the Blackbird and many others.
Posted : 31/05/2018 8:27 pm
I sell it, doesn't mean I understand it*
Likewise I to am an advocate of alien intervention.  I find myself fascinated by things like ancient Egypt, Inca & Greek mythology, and technological peaks.  I find it very arrogant to think we are a lone intelligent species.  To which end I once had an argument on here on the basis of alternative life forms, in that we are arrogant enough to believe our scientific leaders have found the mathematical or scientific rules for everything.    I don't thing so.  There may be and and probably is other beings in a form we can't even comprehend.
Ever read the Lensman series?   Loved that.
Lets lets just hope they aren't reading this (potential TOTY) thread though, they'll be ROFLing even more than usual...
*maybe a little.
Posted : 31/05/2018 8:53 pm
What nonsense.
Posted : 31/05/2018 9:22 pm
As do I.  As a dyed-in-the-wool sceptic I'm reasonably confident that there's other life out there.  It's statistically highly likely.
As for the rest of your post though, my opinion is that it's mince.
Posted : 31/05/2018 9:42 pm
Why Cougar?  Have you irrefutable proof to the opposite?
I'm willing to bet not.
Posted : 31/05/2018 9:46 pm
Why are there no more Space shuttles?
Why are there no more Renault 9s? They were launched in 1981 too. And what are Bucks Fizz doing these days? Or Peter Sutcliffe. Makes you think
Posted : 31/05/2018 9:56 pm
Who is proposing that? Assuming by intelligent you mean human type (as opposed to corvids etc)  given the size of the universe the odds are probably in favour. Although the age of the universe, eg they may have risen and died out, and the uncertainty of what are the chances of life developing makes it uncertain. That is, however, why money has been invested in trying to see if there are any detectable signals. I think you are confusing scepticism about UFOs and the broader question about life elsewhere.
To quote Dara Ó Briain.
“Science knows it doesn't know everything; otherwise, it'd stop. But just because science doesn't know everything doesn't mean you can fill in the gaps with whatever fairy tale most appeals to you.”
Posted : 31/05/2018 10:28 pm
Are you unfamiliar with the concept of opinions?
Posted : 31/05/2018 11:11 pm
Are you unfamiliar with the point of a dialogue to validate your opinion?
You called out the majority of my post as "mince" Cougar, together with the following text I'd assume it's meant as a negative.
Its all very well stating someone's opinion as rubbish in an unqualified manner but at least have the temerity to explain why . If you can't, just say so.  Maybe one day we or our successors will.find out the answer .
Or perhaps soften your response .  It's aggressive, yet you have no counter.
Posted : 31/05/2018 11:21 pm
I am very worried for the authors of the PhD’s theses that 5plusn8 is proofreading.  The application of critical thinking, reasoning and logic are not limited to science or engineering...  With that in mind, it would be interesting to understand the 5plusn8 position on philosophy...
Posted : 01/06/2018 12:00 am
I don't think anyone here is opposed to dialogue. On that basis, have you anything you'd care to use to validate...
... that as an opinion?
Posted : 01/06/2018 1:19 am
@jamj1974
Particularly with regard to the philosophy of science 🙂
Posted : 01/06/2018 1:23 am
or "natural philosophy"
Posted : 01/06/2018 1:39 am
 Spin
Its all very well stating someone’s opinion as rubbish in an unqualified manner but at least have the temerity to explain why .
When something is wrong on as many levels as the post cougar called 'mince' it's virtually impossible to engage with it in a constructive fashion. Such nonsense requires either a massive wordy post to deal with all the issues or a one word dismissal. Some have the patience for the former but clearly not cougar and not me either.
Posted : 01/06/2018 8:01 am
Spin, the phrase you may be looking for is "fractal wrongness". Wrong at every possible level, and no matter how closely you look. ref:  https://rationalwiki.org/wiki/Fractal_wrongness
Other useful phrases in the context of this thread include "Bullshit asymmetry" or "The amount of energy necessary to refute bullshit is an order of magnitude bigger than to produce it." Ref:  https://rationalwiki.org/wiki/Bullshit
And for Kryton57 "Hitchens razor"  "What can be asserted without evidence can be dismissed without evidence" Ref:  https://en.wikipedia.org/wiki/Hitchens%27s_razor
Just one human mind can generate lazy and/or crazy statements, ideas or questions at a massive rate*. If they can't be bothered to put the work into proving it don't ask anyone else to put the effort into disproving it.
* e.g. Aliens built pyramids!
Earth 6000 years old!
Freddie Starr ate my hamster!
Man seen riding flying horse!
WWII bomber found on moon!
All humans infested with souls of ancient dead aliens executed in volcano!
I could go on, but I'm sure humanity will continue to rise up and fill the gaps in our stupidity.
Editto add: And then berate us for not taking them seriously.
Posted : 01/06/2018 9:37 am
There go you then Spin, you basically admitting that you have a strong opinion which differs from mine but have neither the time of will to evidence against it.  Yours and Cougars remains an unqualified opinion therefore and does not prove anything I said as “wrong” in the slightest.   Not an ounce of proof between the two of you.   I admit I also said I can’t prove it, which equally doesn’t make me right either.
You’re both just stating its “wrong” because its off the range of what is currently determined to be “normal” but that could well be a conception that changes in the future (I give you 29” wheels as an obvious example).  Only time will tell.
Posted : 01/06/2018 9:41 am
I work with a woman who thinks the moon landings were faked
Weirdly, she believes we’ve been to the moon, but just the Neil/Buzz landing was faked
Its not that mad .. I  think some of the pictures were a bit too good..
Imagine you've successfully landed on the moon and once you come back you develop your photos only to find that something didn't quite work and you don't have any 🙁
Your currently having a bit of one upmanship with the russians and you may have spent a lot of money so you really need some pretty pics.
Your mates friends making a movie with a really good moon set that you could borrow for a few hours and anyway youll be going back to the moon again so you will get some real pictures , no ones going to notice if you sort of reshoot it and get the nice publicity pics your country needs.
Posted : 01/06/2018 9:45 am
Forgive me if I'm wrong, but you've basically said (from what i infer from your post regarding Ancient culture "myths") and a sciFci series from the '60's) that we've been visited by aliens already?
Unless you've got some proof, then yeah, it's just stories. Having a crack at Cougar and Spin doesn't make them less fictional.
Posted : 01/06/2018 9:53 am
on aliens - check out the drake equation and the fermi paradox
My belief - the zoo hypothesis.  Loads of aliens out there watching us but they are not going to contact us until we prove ourselves worthy 😉
Posted : 01/06/2018 9:57 am
Equally Nickc, does either of the using words like “mince” and “wrong” as the only argument make them any more fictional.  A status quo then.
Like a said, theres a mainstream view, and theres other views.  None of them have been proven without doubt - even the main stream, theres just an implied level of general acceptance.
Posted : 01/06/2018 9:59 am
Kryton
I refer you to my previous post
Its not up to ANYONE to bring the evidence to disprove your nonsense! Its up to you to prove it.
dudeofdoom
It doesn't make sense.
Do you think the Russians were not watching the moon landing very carefully and listening in to the transmissions?
You admit they had a vested interest in the Americans failure, so if the fakery was as obvious as every (conspiracy theorist) says, why the silence from them? (or does the rabbit hole go even deeper than we suspect!)
Posted : 01/06/2018 10:02 am
Errmmm - the moon landings are ture beyond doubt.  conspiracy theories about the moon are proven wrong without doubt.
All opinions are not equal
Posted : 01/06/2018 10:08 am
Yet that statement doesn't written for nor apply only to me does it?   See bold - you too have made an unqualified assumption.    Its not up to me to disprove you, Cougar or Spin either, just because the three of you can't be bothered.
Anyway, we are arguing in pointless circles, lets not continue.
Posted : 01/06/2018 10:16 am
A status quo then.
not really...
the "aliens have been here before" is just made up to fit a 20/21st century cultural zeitgeist, it's just mythic. Whereas at the very least the Fermi Paradox has some mathematic rationale.
Posted : 01/06/2018 10:17 am
Kryton
"A status quo then"
I think you mean that you have forced a draw through your gallant effort (like the knight in monty python)
You have produced an idea from nothing,
Offered no evidence, and
Declared your unsupported idiotic notion equal to all of the scientific, archaeological evidence which does not support your assertion. (Note I didn't say "disproves")
Brilliant!
Posted : 01/06/2018 10:21 am
Neither has anyone else provided evidence against my theory in this discussion, so yes a status quo.
I'm not claiming a moral victory, there's no winners and losers here its just a discussion.
idiotic notion
Is it?  Feel free to enlighten me as to why with factual and evidential data.  Something no one else has provided either in the last 15 hours.
Posted : 01/06/2018 10:28 am
Apologies for the planespottery diversion -
Not quite, the Oxcart was the CIA aircraft, the SR-71 was developed from it for the USAF. The A12 Oxcart is the one on the right.
SR-71 on the left, A12 Oxcart on the right
There's an brief but interesting piece on the CIA website here and a more in-depth look at the program(me) here.
Posted : 01/06/2018 10:29 am
Ok,
The origins of these sorts of stories is based on Cultural Imperialism, (it still sort of goes on; you only have to read Guns Steel and Germs, and the sorts of trashy novels like Lensman) it has at it's heart "Who built the pyramids? After all it couldn't have been Black Africans". In  Carter's days, it was either Greeks (they worshipped at the idol of Classicism) or some other "lost" culture, ie Amazonian, or Atlantis, anything other than the truth staring them in the face, that it was indeed, Black Africans over 6000 years ago, that had built at Geza a building that remained the biggest man made structure for 4000 years.
Still, people (like you) can't quite get over it. It may be subconcious, in some cases (Like Jared Diamond) yer actual racism, but...You still need to ask yourself, what is it that makes you question the evidence that these structures were built by ancient humans?
Posted : 01/06/2018 10:36 am
You overestimate my influence on the outcome of their labour, I just checked for typo's, spelling, repeated words, references and figures coherence, readability etc. My opinions on the content were not required.
(To those of you questioning my grammar, I am better at spotting mistakes, but with my own work I am lazy where it does not matter, on STW it does not matter. Economy of effort.)
2)
The application of critical thinking, reasoning and logic are not limited to science or engineering…
If you read my posts, I never said that. I explicitly denied it.  For example:
This does not mean that if you don’t have any of these qualifications then you will be more credulous.....However I think that the higher the level of physical science education the less credulous you will be about these theories.
When I said
I totally disagree with this hence my theory requiring science education. Arts and social “science” require no understanding of logic and proof, they do logic, but many don’t get it.
I make the point that they don't require it, does not mean that many of them do not use rigorous logic and critical thinking, but many of them do not, and get away with it. That's harder to do with a science background.
3)
With that in mind, it would be interesting to understand the 5plusn8 position on philosophy…
or “natural philosophy”
I don't understand what you are asking? Natural Philosophy is/was the original foundation of  what is now called Science, in fact some philosophers are calling for a reunification of Natural Philosophy and the Philosophy of Science. I have read pretty widely from Russell, Grayling, Feyerbrand, Kuhn , Gould, Pinker Maxwell.
I can't really define a "position" as such, I don't keep up to date with current thinking, and I can't say I remember all that I have read. But be assured that I'm convinced that Philosophy is the basis of science (and maths). What was your point?
As an aside, I don't really want this to be about me, marginally suspicious that the three of you played the man not the ball there. A bit of an uncharitable undertone like "with that in mind", are you trying to make assertions about my character?
I wanted to see if the general consensus was that a decent science education was a reasonable inoculation against specifically the moon landing conspiracies, i.e. once you understand at least some of how it is done, you realise a) how it was possible, b) how hard it would have been to fake.
Posted : 01/06/2018 10:38 am
lensman is not trash!.  Its a key part of SF history.  very very dated tho
Posted : 01/06/2018 10:40 am
I've been off grid for a few days, boy this thread has grown! I just wanted to correct a minor technicality on the Harrier:-
"There have been quite a few attempts to create a jet aircraft that could transition from vertical to horizontal forward flight, and the P.1127/Kestrel/Harrier wasn’t the first to achieve a smooth transition from vertical to horizontal flight, but it was a British aircraft. The Russians tried it, using small jet nozzles on the wingtips, nose and tail. It was a failure. The Americans attempted their own, one a prop-driven aircraft that took off vertically, standing on its tail, with a large contra-rotating prop to propel it. It was a failure as well. It was Rolls Royce who solved the problem using swivelling nozzles on the side of the main jet engine to vector the jet exhaust out of the sides of the plane instead of at the trailing edge of the wings or the tail."
This is true apart from one small detail, it was Bristol Siddley who developed the Pegasus engine, Rolls-Royce then acquired Bristol Siddely in 1966, so Rolls-Royce can't take the credit for the design and development I'm afraid. A small point but one that would annoy a few people I know. It was indeed the small 'puffer' jets in the wing tips and the tail that provided the stability in the hover. They could divert air from the engine bypass duct and generate upto 2000 lb of thrust to control the aircraft in pitch, rolls and yaw. Of course back then this was all done by the pilot, so required great skill, but modern VSTOL aircraft like the V22 and F35 now use computers to fly the aircraft in the transition. Another innovation of the Pegasus engine was that the Low pressure spool and high pressure spools of the engine contra-rotated, this canceled out any rotational forces from the rotating parts of the engine and negated the need for any sort of tail rotor type of mechanism to counter the gyroscopic reaction forces of the engine when manoeuvring in the hover.
5plus8 - I was just playing with words.  No serious point at all
Posted : 01/06/2018 10:41 am
nickc - exactly. It is a shame as Kryton and others are not in any way racist, but have been sucked into the web which helps perpetuate this.
tjagain- no issue.
Posted : 01/06/2018 10:42 am
Kryton
No-one else is making unsupported assertions.
Its up to you to prove what you say.
It is no-one elses responsibility to disprove your notion.
That doesn't make both sides equal.
Am I being unclear?
For clarity, read this  https://rationalwiki.org/wiki/Russel l's_Teapot
"Russell's Teapot draws attention to the formal logic behind the burden of proof and how it works."
If you read that carefully, you may not be any the wiser but you will at least be better informed.
Posted : 01/06/2018 10:49 am
Agree, along with your thinking behind it  - It wouldn't be a stretch to imagine US producing some fake photo's.  This then leads to the naysayers saying the whole thing was faked as the photos don't hold up to scrutiny.
I still don't get the OPs original link between being able to fully understand how you could get to the moon leading to you then not thinking it was faked.  2 completely different things.
Posted : 01/06/2018 10:51 am
eat the pudding:
that absence of evidence is evidence of absence.
There's no proof that Aliens influence our development or have been present on earth,  so in context the lack of such evidence is evidence in itself they didn't do either.
I get that.  But the opposite is also true - see Nickc's post about Pyramids:
Irrefutable evidence and therefore the existents of doubt, vis a vis that absence of evidence is evidence of absence.
I also can't believe it now implied I'm a racist based on these thoughts, only in STW..!
Posted : 01/06/2018 11:15 am
I also can’t believe it now implied I’m a racist based on these thoughts
Kryton, I don't think for a second that you're racist, please accept my unreserved apologies if that's what my post implied, that wasn't my intent at all.
There is absolute proof that all the types of ancient structures that have the mill stone of "Alien worship/help/building" hung around their necks were designed created by ancient indigenous human cultures. Again, think why it is that no-one thinks the English didn't build any number of Castles, but structures that are concurrent with that, (the beginning of Angkor Wat for example) still have a whiff of Eric Von Danikan about them?
And it's repeated, The Nazca lines, Inca Temples...any number of Meso-Mexican temples...and on and on.
Posted : 01/06/2018 11:29 am
Theory? You mean "what I reckon" don't you?
Posted : 01/06/2018 11:49 am
Before we move on to other things I'd like to add my name to 'you're talking mince' camp.
Posted : 01/06/2018 11:51 am
Yeah the Colliseum was just hard working Romans - although it wasn't built in a day
But Machu Picchu and Teotihuacan needed friendly aliens
Posted : 01/06/2018 11:59 am
Kryton
Still no evidence to back up your notion then.
Oh dear, how sad, never mind.
Posted : 01/06/2018 12:00 pm
 Spin
I'm sure someone upthread has said this already but...
What you're doing is known as shifting the burden of proof and it's a fallacious argument form. If you make an outlandish claim it's up to you to supply evidence of it, not up to me to refute it.
Posted : 01/06/2018 12:02 pm
I'm not going to get pulled into implied insults or derogatory comments, its been interesting, thanks Nickc mostly as there's some direction to some interesting reading for me, but - I'm out.  🙂
Posted : 01/06/2018 12:10 pm
As an aside, I don’t really want this to be about me, marginally suspicious that the three of you played the man not the ball there. A bit of an uncharitable undertone like “with that in mind”, are you trying to make assertions about my character?
5plusn8.  I  very sorry if I have come across that way - I have no intent to make any negative assertions on you character.  No undertone or overtone of that nature was meant.  Please accept my apologies.
I (Understandably, I believe.) inferred that you were questioning the presence of critical thought in non-science or engineering degrees.  That I would disagree with.  That is all - nothing else and certainly not questioning your grammar.
Posted : 01/06/2018 2:12 pm
Or perhaps soften your response . It’s aggressive, yet you have no counter.
It was not meant to be agressive, and I'm sorry if it came across that way.
As for a counter, well, you're right, I don't have one. Because it's not possible to have one. This is a lazy way of trying to give credence to random beliefs because it's impossible to disprove a negative. It's Russell's Teapot, or if you like, the majority of god-based religions.
I can say with a degree of confidence that there's no such thing as god. The theists go "prove it" and I can't, because it's not possible. It will only ever possible to prove them right, by finding some form of evidence to substantiate their belief. The fact that over millennia not a single shred of evidence has come to light to support this idea coupled with Occam's Razor leads me to conclude that our modern notion of "god" is likely beyond reasonable doubt in my mind to be a man-made construct. But I can't prove it.
Which leads us nicely to a thing called Burden of Proof. See, I don't have to prove anything. If you're making wild claims about alien technology (or god) then it's your responsibility to put forward supporting evidence to back up your claims if you want them to be taken seriously. If you can show us something that proves what you're saying then I'll believe you (and you'll also be very, very rich). If all you've got is tinfoil-hat conspiracy theories then I'll cheerfully dismiss them as mince, or some other less-aggressive term for "nonsense" if you prefer.
Posted : 01/06/2018 2:24 pm
Cougar, this is the point about science, and the philosophy of science that many non scientists (and scientists it has to be said) do not get. Science is never right, any theory backed up by evidence and experiment just has the best explanation until better evidence comes along.
Things like Newtonian Physics, (I know you know this anyway) without some serious equipment it is hard to find flaws in Newtonian Physics, it is demonstrably correct in 99.99999% of everyday observable situations, but we know that in theory it is wrong and everything is controlled by Quantum Physics. So it is equally feasible that at some point in the future Quantum physics will be wrong and we will have a greater theory (Hawkin was heading that way anyway) .
Posted : 01/06/2018 2:54 pm
Well Quantum Physics in combination with General Relativity - which is the the theory that explains some of the slight observational flaws in Newtonian Mechanics  - the orbital precession of Mercury being the most commonly cited example.
We actually already know its wrong or rather that its at least incomplete - it doesn't incorporate gravity at all.  Likewise General Relativity doesn't work at quantum scales
Richard Feynman once said that science was "a satisfactory philosophy of ignorance".  Science just gets on with the job of being less "wrong" I don't think its ever trying to be completely "right"
Posted : 01/06/2018 3:09 pm
Page 3 / 4
