I screwed up and deleted mmtracker from my phone now unavailable at the appstore due to memory map having a whinge. Any ideas how to manually install it or are there similar apps around?
it's ok used google instead of site search
http://singletrackworld.com/forum/topic/mm-tracker-where-did-it-go
aptoide seems to work.
MMTracker is no longer supported and doesn't work on the latest version of android, there was a rumour that the developer got a job at Ordnance Survey, I hope that's true:) Try AlpineQuest dgd
MMTracker v1.10.4 works on Galaxy Note and Note 2 both running Android 4.1.2.
It doesn't work with 4.2.1 and above, not sure about 4.2, so if you want to keep it working don't upgrade the OS.
appreciate the info guys
AlpineQuest will display the older MemoryMap maps (.QCT) and comes in a free version.
If you have licensed maps, MM now do their own Android application.
