Man Shed roofing - ...
[Closed] Man Shed roofing - advice needed.
Right - I'm about to start the construction of a new man shed. It'll be approx 11' x 14' with a flat roof (will have a slight slope, around 10 degrees)
Shed will be 100mm 7nm concrete blocks, being layed by a mate, but i'm doing the rest (ie - the roof)
I'm confident about tackling it, I've worked with wood a lot in the past, inc some pretty big structures.
Basically i'm looking at a 4" x 2" joists, paneled out in sterling board.
I was thinking about a corrugated steel roof, however i'm a bit put off by the cost, so am now thinking about felting it.
Sooo... can anyone recommend what felt to buy, and where to buy it?
I've got no objections to 'torch-on' felt, I've got a propane torch with the right nozzle etc.
any other thoughts/tips/advice would be most welcome.
Posted : 12/03/2013 10:58 pm
My dad re roof a lean too a few years ago and used these corrugated sheets. They seem to work well a more reasonable price than metal corrugated sheets but not brittle like the plastic ones.
http://www.screwfix.com/p/coroline-corrugated-pvcu-bitumen-sheet-black-2m-x-950mm/27586?kpid=27586&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&gclid=CNfI5vaX-LUCFUfMtAodMRIALg
Posted : 12/03/2013 11:07 pm
Quite a long span for 4x2 is my first thought.. Minimum three rows of nogs, two outer edges and one down the centre. Ping a chalk line and stagger them either side so as to be able to nail them easily. Notch wall plate straps in at 900 ish centres as that's a big flat sail. Use ring shanks to nail the ply down, nail the ply down in the right place or wish you hadn't used ring shanks.
Posted : 12/03/2013 11:15 pm
OK, so maybe 5" x 2" might be better bet?
My other thought is fire rating - because my shed is within 1m of the border it needs to be build from fire proof material, I've got this covered with the wall construction, but need to consider it for the roof I s'pose?
Posted : 12/03/2013 11:18 pm
Two skins of plasterboard on the ceiling side or something like a supalux board which is fire resistant, again screwed to the underside of roof joists.
Posted : 12/03/2013 11:21 pm
cheers Wrightyson.
TheBrick - thanks for the link, looks interesting.
Posted : 12/03/2013 11:23 pm
I'd up the timber size purely because you're going to have to get up there and work on it, plus you don't want any flex if you go for a bituo/felt type roof.
6x2 as a mininum assuming the span is 11ft and not 14ft! Noggins at mid span up to a 4.5m span
10 degrees is a bit OTT. Look a installing the joists flat and using a precut firring option to keep the construction simple to a 1:60 fall
Less then 1m from the boundary the garage needs to constructed substantially of noncombustible materials. You're be fine with the timber internal construction just dont go putting timber cladding or a thatch on the outside.
Be wary of internal condensation problems with a single skin metal deck.
Posted : 13/03/2013 12:13 am
