OK, so Mrs A and I have 4 small businesses, sole trading each, and one is finishing this week.
Mrs A has 1 business in her name with a personal bank account in her name, I have 1 in my name (bus bank account in my name) and we have 1 in joint names (joint personal account). Each business is simple (rental; hairdressing from home and occasional consultancy) so it's largely regular income inputs via bank transfer, expenses out and wages. That's it. We have an accountant who does our year end tax return. I'm diligent with record keeping.
Whether we'll hit the MTD threshold is debatable but I'm working on the assumption we will.
Looking at MTD software, I can use it with my bank for free on my business as it has a business bank account. Mrs A has tried to get a business acc for her hairdressing but has been refused by several banks, incl. the personal one she currently solely uses for it. So we'd have to get 3rd party software ... is that the way to go as my investigations suggest it gets pricey and complicated.
As they're simple businesses and I'm au fait with excel, wondering if a bridging program makes sense? Presumably we'd need 1 program per business? If it's possibly a good solution, any recommendations?
And also, if the joint business (rental) received its money into a business bank account solely in my name, does that compromise us as we share the income 50-50 for tax benefits?
Thanks!
Quite a tangled web, what did your accountant say?
Personally I’m one person with one business linked to one (personal not business) bank account that I use solely for business transactions. I’ve linked that to a basic QuickBooks account and hope quarterly submissions are going to be a matter of pushing a button.
We're in a similar position (but I do our tax and accounts rather than employing someone else). I've signed up for, but not started using, Clearbooks. £60+VAT per year seems reasonable and means it has some support (and with an income stream it might stay around - having migrated between accounting systems before for a small business I'd avoid it as much as possible)
https://www.clearbooks.co.uk/pricing/
Response 1
You’re thinking about this in exactly the right way—keep it simple, compliant, and proportionate to the size of the businesses. Let me break it down clearly.
🧾 1. Your setup vs MTD (Making Tax Digital)
Under HM Revenue & Customs’s MTD for Income Tax (starting from April 2026 for many sole traders/landlords):
You’ll need:
Digital records
Quarterly updates
Final declaration (replacing Self Assessment)
👉 Important:
MTD applies per individual, not per business.
So:
You → 2 businesses (your sole + joint share)
Mrs A → 2 businesses (her sole + joint share)
💻 2. Do you actually need full accounting software?
Short answer: No — not necessarily.
Given your situation:
Low transaction volume
Mostly bank transfers
No stock / complex VAT
Comfortable with Excel
👉 Bridging software is absolutely a viable option and widely used in cases like yours.
📊 3. Excel + Bridging software (good fit for you)
This approach:
Keep records in Excel (as you do now)
Use bridging software to:
Submit quarterly updates
Stay MTD compliant
✔️ Pros
Cheap (£0–£50/year typically)
Keeps your existing workflow
Minimal learning curve
❗ Cons
Slightly more manual
You must structure spreadsheets properly
🔧 Popular bridging options (UK)
Here are commonly used ones:
BTCSoftware MTD Bridging
→ Very popular with accountants, simple, reliable
Absolute Excel VAT Filer
→ Cheap, lightweight
TaxCalc MTD
→ More full-featured (can grow with you)
Andica MTD Bridging
→ Budget-friendly option
👉 Expect ~£30–£100/year depending on features.
🧩 4. One software per business?
This is where it gets interesting.
Because MTD is per person, not per business:
👉 You may be able to:
Submit one combined quarterly update per person
With:
Separate income streams (each business tracked in Excel)
✔️ So:
You → 1 submission (covering both businesses)
Mrs A → 1 submission
👉 That means:
You likely don’t need separate software per business
Just:
Clean separation in spreadsheets
Clear totals per business
💡 Your accountant should confirm their preferred structure (some want separate feeds).
🏦 5. Mrs A using a personal account
This is not a problem for HMRC.
HMRC cares about:
Accurate records
Digital trail
They do NOT require a business bank account.
👉 So:
Keep using personal account ✔️
Just ensure:
Business transactions clearly identifiable
Ideally a separate column/tag in Excel
🤝 6. Joint rental income paid into your sole account
This is a really good question.
Does it break the 50/50 split?
👉 No — provided the beneficial ownership is genuinely 50/50.
HMRC looks at:
Ownership of the asset
Not whose bank account receives rent
So if:
Property is jointly owned ✔️
Income genuinely shared ✔️
Then:
Declaring 50/50 is fine
⚠️ But best practice:
To avoid questions:
Keep a clear audit trail, e.g.:
Transfer 50% to Mrs A regularly
Or track her share clearly in records
💡 7. Practical recommendation (your situation)
I’d suggest:
✅ Stick with Excel
✅ Use bridging software (1 per person ideally)
✅ Keep:
Separate tabs per business
Clean summaries per quarter
Avoid (for now):
❌ Full accounting software subscriptions
(unless things grow or MTD gets stricter)
🧠 Bottom line
Bridging software = perfectly sensible choice for you
You likely don’t need multiple subscriptions
Personal accounts = fine
Joint income into your account = fine (with records)
👍 One thing I’d clarify with your accountant
Before committing:
👉 Ask them:
“Do you want quarterly submissions per business or per individual?”
That will determine:
Whether you need 1 or 2 software setups
Response 2
You’re thinking about this in a very sensible, structured way—and for simple sole trades like yours, it’s worth resisting the temptation to overcomplicate things just because of Making Tax Digital (MTD).
Let me break this into the two key parts: software choice (bridging vs full software) and the joint business / bank account question.
1) Bridging software vs full MTD software
Given what you’ve described (low transaction volume, mostly bank transfers, Excel confidence), bridging software is absolutely a viable—and often ideal—solution.
Why bridging software fits your setup
You already keep clean records ✔
Transactions are simple ✔
No need for invoicing, payroll, stock, etc. ✔
You have multiple small businesses ✔
Full software like QuickBooks or Xero becomes expensive quickly when:
You need multiple subscriptions (one per business)
You don’t actually use most of the features
That’s where bridging shines.
How bridging software works (in practice)
You:
Keep your records in Excel (as you do now)
Categorise income/expenses to match HMRC boxes
Upload or link the spreadsheet to bridging software
Submit quarterly updates + final declaration
No bank feeds, no automation—just clean, controlled reporting.
Good bridging software options (UK)
Here are some widely used ones:
TaxCalc (has bridging module)
BTCSoftware
Andica MTD
For MTD for Income Tax (when it fully applies), expect similar tools to adapt.
Do you need one per business?
Yes—practically speaking, each business needs to be submitted separately.
However:
Some software licences let you manage multiple businesses under one login
Others charge per “client” or “business”
👉 This is the key cost question—worth checking before choosing.
My honest take for your situation
Given your setup:
Start with bridging software
Keep using Excel (you’re already doing it right)
Avoid committing to monthly subscriptions per business
You can always upgrade later if things grow more complex.
2) Mrs A using a personal bank account
This is very common, especially where banks refuse business accounts for certain trades.
From an HMRC / MTD perspective:
Totally acceptable, as long as:
Transactions are clearly identifiable
Records are complete and separate from personal spending
MTD does not require a business bank account.
3) Joint business income paid into your sole account
This is the more subtle point—and you’re right to question it.
Short answer:
No, it doesn’t compromise the 50/50 tax split—if handled properly.
What HMRC cares about:
Who owns the business / income
How profits are allocated
Whether records support that split
Not strictly:
Which bank account receives the money
But there are practical risks
If income goes into your sole account:
It can look like it’s your income
Especially if not clearly documented
How to protect yourselves (simple steps)
If you do use your account:
Keep clear records showing 50/50 ownership
Transfer Mrs A’s share regularly (or record it clearly)
Maintain a simple profit split working paper
Ensure your accountant reflects this consistently
Cleaner alternative (recommended if possible)
Use a joint account for the joint business
OR
Keep using current joint account (which you already have)
This avoids questions entirely.
Bottom line
Bridging software + Excel = very sensible choice for you
You’ll likely save money and keep control
One setup per business is needed, but some tools handle multiple
Mrs A using a personal account is fine
Joint income into your sole account is technically OK, but cleaner to keep it joint
I'm not sure if this is too simple a solution for your quite complex question bit - if you've got an accountant doing your tax return calculations anyway why not just have them submit the return? The MTD software is basically bookkeeping software for individuals thats enables them to also make digital submissions to HMRC - but you're getting an accountant to do that bookkeeping so just get them to submit it on your behalf. Otherwise you're paying for software that you're only going to use for 15 minutes a year.
EDIT
also
Thanks all ... liking the look of VitalTax bridging thingy
