Log burner advice
[Closed] Log burner advice
 bash
We've had our log burner for a week or so now but I could do with some advice. I seem to be OK at getting it going with lots of flame and heat by leaving the door ajar for 5-10mins, then closing the door but leaving both air vents wide open. The issue I'm having is that after another 10 minutes or so it pretty much goes out. The big log that I put in has started to catch and the embers are glowing red but not flame or heat.
I'm lighting it by putting two logs on the bed of ash, Kindling in top, good few handfuls then scrunched up newspaper on top of that.
Stove is a Dunsley Highlander 5 with a twin wall flue going up two storeys.
Posted : 29/03/2017 1:54 pm
If it is dwindling then it simply hasn't got hot enough when you turn it down.
What we do is put a single firelighter in the middle of the fire then a criss cross pattern of kindling on top (about 4 layers high) and light. When that has taken we add some *small* logs (often smaller pieces split with my axe unless I can find some smaller ones in the 1 tonne bag) then, when they have taken, start adding progressively larger logs.
Of course you also need to check your logs are good and dry.
Edit - a bit like this but I only use two pieces per layer (as it is a small fire)
Posted : 29/03/2017 1:56 pm
newspaper on top of the ash, kindling then logs on top. That way the heat of the paper burns through the stuff above.
Need to get it hotter though, so consider more kindling or better burning kindling to get going better.
Posted : 29/03/2017 1:58 pm
Tried that upside down method, never really got on with it, went back to normal - newspaper below, lots of kindling and a couple of SMALL logs atop.
Posted : 29/03/2017 2:00 pm
I put a firelighter in the centre of the grate then decent sized logs to either side to basically funnel as much air flow as possible past the firelighter. Kindling/small bits of wood on top of the lighter with some larger bits on top of that. Then shut the door.
If the wood's dry enough then you can often just put a large lump of wood straight on top of the firelighter - the draught will pull the flames and heat through the gaps between the logs and get everything going.
Posted : 29/03/2017 2:04 pm
Vents open
"v" shape with 2 large logs (I dont bother with ash on the bottom)
newspaper in between
half an egg carton or couple of cardboard toilet roll inners on top of that
kindling on top of that
slightly bigger sticks on top of that
small log on top of that
Leave the vents open (door open slightly too if necessary) for 3-4 minutes
then vents down half way for 10 mins
then vents open just a smidge for the rest of the time you've got it lit.
another thing to bear in mind is when you start adding the big logs try to avoid going straight for a hardwood log such as oak. something soft like pine or larch that burns quickly is better. I try not to put the hard wood on until there are lots of embers /heat already in the burner.
Posted : 29/03/2017 2:09 pm
Not quite right....
Logs on ash > paper (or small bit of firelighter) > sticks > another log or two
Paper/firelighter starts the sticks which starts the log which lights the bottom logs. You shouldn't have to add more fuel for 20-30 mins
If it goes out you've either not got enough sticks or the wood is not dry enough.
Upside down lighting FTW.
Posted : 29/03/2017 2:24 pm
Are you absolutely sure you are opening both vents fully? Are you also sure that your wood is dry enough.
All the fancy stuff about building an inverted pyramid of various timbers dried by virginal pygmies is a load of guff. Chuck in a fire lighter, loads of kindling and a (slightly dry) log on top. Door open 10 minutes. If log still hasn't taken, more kindling.
I find my stove works best when you get it up to temp quickly.
Posted : 29/03/2017 2:26 pm
yep.... there needs to be a log at the top of the pile otherwise there's nothing to burn! The logs at the bottom just help the fire to get going quicker.
Posted : 29/03/2017 2:37 pm
While i agree with everything above.... Are you sure your logs are dry? I can go from match, to large hard wood log roaring and vents closed in about 5 minutes usually, but i know i have dry wood.
Posted : 29/03/2017 2:41 pm
My method, Criss cross stack of kindling with 14 sheets (28 sides) of tabloid paper balled in and around. 2 medium logs on top. Vents open, match, door ajar. As flue temp passes 100C shut door. After another 2 or 3 minute flue temp will peak around 280-300C and that is when another large log goes on. Watch for 60 secs and as soon as flue temp starts to climb again, close vents and walk away. I always start with a clean grate. No bed of ash.
Posted : 29/03/2017 2:46 pm
What's with the whole logs at the bottom thing? I've never ever done that, not even once. I can't think of a situation where that would actually be beneficial. Or are we all Scandinavian now?
Posted : 29/03/2017 2:53 pm
What happens if you only use 13 sheets?
Posted : 29/03/2017 3:05 pm
I've spent the last few months burning the contents of my old house, which has been mostly pine and easy to burn. Just recently took delivery of a builders bag of hardwood and really struggled with it for the first few fires as it requires a bit more skill (or more paper, card and kindling) to pass that tipping point where it won't die out. Just persevere with it, using a bit more paper/card/kindling. I've found that there def is a tipping point either in the flue or box where, if you don't pass it, it's going to die out. I've also found that top down requires a bit more skill/knack, so maybe start with the standard method and get good at that before trying top down again.
Posted : 29/03/2017 3:16 pm
I used to use 13 sheets.... My dad has for years. Then i had a failure, so now it's 14 and never failed. You need to get the flue hot fast. The flue heat drives the draft and hence the fire, lots of flue heat fast will also stop creosote formation, plus strong draft and heat in the firebox will get the secondaries working fast and a clean burn. Best way to get heat fast is paper and small kindling, and plenty of it. If you want a scare throw lots of kindling on to an established fire and panic as stove top temps race to and past 350 ish C with the vents closed!
Top down is recommended by morso and other manufacturers as it's supposedly a bit cleaner, less smoke. Bottom up done right only smokes for 30 seconds and i find it easier.
Posted : 29/03/2017 3:33 pm
As the sticks burn bits of burning embers fall onto the logs and light them rather than just falling into the ash and dying. Fire also spreads downwards, so if you burn something on a dry log the log itself will start burning.
It's just more efficient ..... so yes, Scandinavian!
A good flue should have plenty of draft without a fire - but it certainly helps.
Posted : 29/03/2017 3:37 pm
I just thought, the spring weather won't help you. Weather affects the draft alot. If things are damp outside draw is less, and if things are warm outside draw can be very very little. If draw is troublesome in your setup, open a window and/or warm the flue with a blow torch.
Posted : 29/03/2017 3:40 pm
Yes a good flue would draw full stop. If it's straight up, tall, outlet in a good spot and the stove has sufficient ventilation it will roar. However the physics are the hot air, less dense, rises up the flue and fresh cool, dense air replaces it. The bigger the temp difference, the stronger the draw.
Posted : 29/03/2017 3:46 pm
Fair enough, sharky, I'll give that a go and see what happens.
Posted : 29/03/2017 3:47 pm
In addition to [b]neilnevill's[/b] points; ensure you have enough ventilation coming into the house. A mate of mine (who has a new build house) couldn't light his stove and we eventually realised that all the UPVC and draught proofing was inhibiting the fire's draw.
Posted : 29/03/2017 3:51 pm
I suppose the only real question left is...
Have you ever tried just 12 sheets?
Yeah i used to be foolish, i tried 10 or 12 sheets. I was so wayward i didn't even count. It lit but was a struggle. Then my dad can passed on the 13 sheet way and i never looked back.
Posted : 29/03/2017 4:18 pm
I was having similar problems with mine although down to a dodgy door & glass seal. My challenge was it would roar away but put no heat out and if i damped it down it would virtually go out.
I invested a fiver in one of these that goes on the flue if you can get to it, and helped make sure i always had the fire running at the correct temp. https://www.amazon.co.uk/gp/product/B00F92EB18/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
As above my leaky seals meant it was drawing far too much air so i had to change the vents all the time, but monitoring the temp meant we didn;t burn anywhere near as much wood and the fire put out more heat.
Posted : 29/03/2017 4:30 pm
aye, this is what I do - basically just build a normal fire, perched atop a big log (flat side up).
it'll usually go for an hour before needing any more attention ๐Ÿ™‚
Posted : 29/03/2017 4:33 pm
 ski
Sounds like your wood is not seasoned enough to me?
Posted : 29/03/2017 4:40 pm
Following with interest as sometimes similar issue, but have definitely noticed difference between wood bought in and stuff from father in law's wood store, so don't underestimate seasoning of wood.
Posted : 29/03/2017 4:50 pm
Its either, or a combination of:
Not enough small logs on top of the kindling (you needs lots of surface area). I saw pallet wood into 15cm lengths and then split it so they are random sizes from about 15mm square and up.
Closing the air down to fast, the stove needs to start retaining heat so when your sticks are well alight, close the bottom air vents gradually. Get a flue thermometer, if you start closing the air you should see the flue temp go past 50 degrees C pretty quick.
Adding large logs before the stove is getting hot (flue should be getting too hot to touch comfortably by the time you add logs.
Unseasoned wood...should be no hissing or moisture escaping from the end of the logs.
Once mine is nice and hot, the flue temp normally reads around 160 degrees C, bottom vent all the way shut and top vent about 80% open. This gives a nice lazy flame, the glass stays clear and most of the time, the fire bricks stay beige/clean. Sometimes they blacken up during the first 30 minutes or if I put damp wood or pine in the stove, but they burn off pretty quick.
If you leave the vents open, all the heat just shoots straight up the chimney and the stove never gets hot enough to close the vents down.
Finally, as the stove is dying down, give it some extra air so it can burn out quickly, rather than smouldering away after you've gone to bed, and turning the glass black.
Posted : 29/03/2017 5:58 pm
 dyls
Use kindling, then some smaller logs on top and then the larger logs. Make sure the logs are dry as well.
Posted : 29/03/2017 6:18 pm
I use the Top-Stoking method. 2 logs at the bottom with a "valley' between them. Tiny piece of fielighter in the valley. 7/8 pieces of kindling on top. Small log on top of the lot.
One match to the little bit of firefighter, close door, open vents, 2 minutes to roaring fire. Every time.
If the logs are too close to the front of the firebox it can affect the airflow. This stoking method, used by the Scandinavians, is very efficient, because as the kindling heats the bottom logs and they start releasing gas, the gas is ignited by the kindling, instead of being wasted up the chimney in the old fashioned method.
Posted : 29/03/2017 6:37 pm
As suggested above, top down should work ok if constructed reasonably well, I find it much less smoky compared to conventional. Problem I sometimes have is the paper basically blowing itself out before the kindling is properly caught, mostly cos I'm too stingy with both (I don't have unlimited supplies of paper and kindling takes a bit of effort to make). Paper knots are better than just scrumpling up IME, and sticking bits of kindling through the knots keeps good contact between the two and stops the paper falling off as it burns.
Posted : 29/03/2017 6:56 pm
 bash
Thanks for all of the advice. I suspect all those that are saying I'm not getting enough heat into the flue are correct. I'll order a flue thermometer so I can at least relay some numbers if I'm still having issues. I'll give it a go using the normal way rather than inverted and see how I get on. I think I may be also putting the big hardwood logs on too soon as well. (So basically getting most things wrong :))
I'll get a moisture meter and check the logs but the merchant has come recommended, could always be a bad batch I suppose.
Posted : 30/03/2017 12:12 pm
If you buy logs in you should always buy them well ahead of time as these will be the driest ones...... towards the end of the season the chances are that the logs will have not been split long and therefore will be wet.
Take a look at Arbtalk and see how many sellers are trying to buy loads of wood because they've sold out. Once split these logs will still be wet.
If you have the space you should be looking at your wood supply for 2018/19 right now!
Posted : 30/03/2017 12:27 pm
it does also depend on the log type. I find, my dad, and my brother, that oak can sulk. Its like it gets lonely, i needs company. I've been burning oak I've seasoned for 3 years, 18% moisture on over a dozen fresh splits (I checked it), but a single log on its own slowly dies down. it will burn with lots of air, but slowly. Soft wood actually contains slightly more calories per kilo as its got more VOCs like lignin it also burns much more freely. So it may just be you need a couple of smaller bits, not one large log.
Posted : 30/03/2017 12:31 pm
Regarding flue thermometers, does anyone actually have a single skin flue? If insulated, is the measurement useful?
Also, yes as above two bits of wood are always better than one IME, the extra surface and air gaps makes everything work much better. Not always easy when you've got some huge knotty chunks that each fill the firebox!
Posted : 30/03/2017 12:45 pm
Interesting, but does this apply to modern stoves with secondary burning?. There's flutes of flame coming out of the holes in the back of mine, almost straightaway.
Posted : 30/03/2017 12:54 pm
Yep, bit out the top of ours is single skin, regularly see 350C on the thermometer whilst getting it up to speed. Normally, run at 250C once it's heated up.
Posted : 30/03/2017 1:04 pm
I think its normally single skin when your flue goes into a chimney? Even twin wall presumably starts at single skin directly above the stove?
Footflaps, must be farenheit ๐Ÿ™‚
Posted : 30/03/2017 1:21 pm
Surely majority will be single skin. The valiant one sits directly above the box, which is useful if space is tight (i believe some sit higher up the pipe).
I'm not so sure about that as gas is only released from the wood once stove temperatures are much higher than can be achieved with kindling in the first 10 mins of burning.
It only relates to starting the fire. AFAIA the secondary burn does not start until the stove temp is well over 200c.
Posted : 30/03/2017 1:24 pm
Nope Centrigrade..
Stove fan won't be up to speed until the Stove body is about 200C.
Posted : 30/03/2017 1:45 pm
Definitely Celsius. Proper operating range is about 110C to 270C ish. Above that you waste more energy up the flue and as you get to about 400C you're in danger of damaging stove and flue, although a short blip probably OK.
Posted : 30/03/2017 3:54 pm
My thermometer goes reads 'too hot' at 250C/475F.
It got close to 250C once and the stove was doing a good impression of a blacksmiths forge, and the metal strip under the fan was starting to tilt it off the stove to stop it overheating! Stove top (and stove) is obviously is rather hotter than the flue which is thinner and has plenty of surface area to dissipate heat.
Posted : 30/03/2017 6:25 pm
From experience you are not getting enough airflow we into the stove.
I live in a very late 80's timber framed property that has modern well sealed windows and sometimes when the weather conditions are right I have to open the longs windows to assist the flue in drawing air through the stove. Once it's burning and up to temperature it's fine.
So before you start doing anything else I would check that your room is ventilated correctly to enable the stove to operate.
Remember Carbon Monoxide can kill and if you stove have been installed according to Regs you should have Carbon Monoxide monitor in the room anyway.
Posted : 30/03/2017 7:52 pm
OP - what is the max output of the stove?
Posted : 03/04/2017 8:14 am
I think you might try splitting a few logs. Insides may catch fire faster than outsides, and the inside corners should go quickly.
And scrounge a few logs from someone else to compare with yours. It does read like yours are damp.
Posted : 03/04/2017 8:34 am
Yep, what the git said ^
Why don't you try lighting it using your usual method with just lots of kindling, and maybe some thicker sticks, and see what happens.
If it still dies out it's an air supply issue (in which case open a window slightly during the first 10 mins) or you'r logs aren't as good as you/the log seller think they are.
Posted : 03/04/2017 8:44 am
 br
A couple of observations:
You can never put too much kindling on
You can never have too many firelighters
If your house is so airtight that you've to open a window to get the fire to draw, you don't need a stove - just switch on your central heating instead ๐Ÿ˜‰
Posted : 03/04/2017 8:56 am
From my understanding (from what our fitter said), if a stove is >5kw then additional venting is required. For <5kw venting generally shouldn't be required.
Posted : 03/04/2017 9:14 am
 br
[i]From my understanding (from what our fitter said), if a stove is >5kw then additional venting is required. For <5kw venting generally shouldn't be required. [/I]
This is a legal thing.
Posted : 03/04/2017 9:43 am
Yeah that's true ๐Ÿ™‚
Posted : 03/04/2017 9:44 am
Jeez. How complicated can people make lighting a fire? Just get it lit, chuck more burnable stuff on, the hotter the fire, the bigger the burnable thing can be. Don't turn down any vents until the fire is set in properly., then close them all progressively until you are maintaining temp with just the airwash. Don't over think it!
(Edit; 13 sheets FTW)
Posted : 03/04/2017 12:52 pm
@ bash - I just re-read your original post, for last night I lit a fire and thought about it. I too have a Highlander five, though seven years old. I assume they haven't changed much.
The instructions say don't leave the door open. I shut mine quickly, especially when it's going well as it starts roaring. This makes me think you have damp wood. See if you can scrounge some dry logs from mates. I'm in West Wilts.
It may help to use kindling then smaller logs to start, round ones about 2 3" dia, or the equivalent size in split pieces. As it gets going, add one more, bigger, at a time. The aim is now two sideways and one diagonally across the top.
Each time a new piece goes on, prod and poke the bottom-most, for you want to have a layer of red-hot charcoal at the bottom. When you have that you can add one of the biggest logs. And when that's nearly done, prod, poke and spread the charcoal again, then add another.
If it sounds a lot, well I usually start the fire while I'm cooking my dinner, fortunately I can see it from my kitchen.
Posted : 07/04/2017 8:59 am
