Just cancelled Sky ...
[Closed] Just cancelled Sky TV..
 stox
Don’t watch much on it. Been thinking about it for a while. Letter in the post today increasing it by a fiver a month.
When I look at my estimated bills it increases another £15 a month in July!
They offered a deal which was poor but short of them offering free tv there was no way I was staying anyway . Had enough of them.
So what do I do now - freesat box?
I have a 1 year old 4K Smart Sony TV.
I’d like the ability to record / pause shows like I could with sky.
Do I just pick a box to suit budget and hard drive size?
Posted : 08/03/2021 2:13 pm
Check the features / specifications of your TV. You may be able to just plug in a USB drive to record onto.
Posted : 08/03/2021 2:17 pm
Binned off Sky years ago, now have pretty much all the streaming services (including Sky, in the form of Now TV 😀) for less. Don’t even have an aerial hooked up!
You THINK you need to record/pause live tv but actually, once you get out of the lifetime habit of watching channels, you don’t! Pretty much everything you’d want to see is available on demand using apps,etc so just watch what you want when you want, not just because something is “on” 😀
Posted : 08/03/2021 2:18 pm
Surely a 1yr old tv has freesat support built in?
Cant remember the last time i watched anything that wasnt streamed... maybe 7 years ago??
Posted : 08/03/2021 2:20 pm
I've just done the same (actually stopped working on the 5th). Both my 9 year old Panasonic Plasma and the 5 month old LG will pause and record onto USB hard drives (I've just used old 2.5" drives I'd already replaced with SSDs) - unsurprisingly the latter better than the former.
The only thing they can't do is record one channel whilst watching another - but they will record one TV whilst you watch another input (i.e. chromecast, etc.)
Maybe try that first before going to a freesat box?
Posted : 08/03/2021 2:21 pm
I've had the same letter. £5 increase. I'd go BT as I mostly watch sports and their sports package is so cheap... but! they insist you have their broadband too! WFH means reliability and speed are key with broadband and I don't trust BT enough. Not enough to change from Zen anyway, which has been perfect.
If I changed, I don't think I'd be so bothered about recording stuff now almost everything seems to be available to stream.
Posted : 08/03/2021 2:22 pm
Most tellies don't. Only - if memory serves - some Samsung and LG models have it built in. It is very good though - used it for the past 10 odd years
but the set top box is small now https://www.freesat.co.uk/why-freesat - and can record - apparently - four shows at once
Posted : 08/03/2021 2:25 pm
Absolutely agree - although the ability to pause is handier than the ability to record.
Mrs SB might need a bit more persuading, but there's not much she can do about it now.
Sky are screwed ultimately.
Most tellies don’t. Only – if memory serves – some Samsung and LG models
My old Panasonic does both (as does the LG) - I've gone to Freeview though as CH4 isn't available in HD on Freesat.
Posted : 08/03/2021 2:28 pm
 stox
No I already checked and there’s no freesat support within the tv
Plug the aerial in then - there's no difference in picture quality that I can see.
Posted : 08/03/2021 2:31 pm
I sit corrected then. Quick look at the JL website implies 30 odd for both Samsung/LG, and 2 for Panasonic. And 1 for Linsar, whoever they are!
Posted : 08/03/2021 2:37 pm
Setup we have here is Chromecast dongle attached to TV. We watch stuff from YT & Prime and (having read through the "you need to have a license if..." list and gone "we don't do that" to the lot), got rid of the tv license.
Happier and richer !
Posted : 08/03/2021 2:45 pm
I was wasn't so obsessed with F1 I would bin Sky too. But unfortunately they have exclusive rights in the UK for the next few years.
Plug the aerial in then – there’s no difference in picture quality that I can see.
^^That - Freeview HD signal is plenty good enough.
Would getting a Freesat box mean getting the dish repositioned to pick up different satellites?
Posted : 08/03/2021 2:48 pm
We stopped paying for Sky over ten years ago, we just weren't watching anything. Now we have Netflix which is vastly better value for money. Literally more good stuff on there than we can actually watch, and for what, nine quid?
Posted : 08/03/2021 2:49 pm
NO..... it's exactly the same. unplug sat cable from sky box and plug into freesat box (or TV) - job jobbed.
Posted : 08/03/2021 2:54 pm
Your TV should record if you have a few USB sockets. Our Samsung does, but we never use it. Nor the 'once' expensive PVR.
Normal Freeview, then Netflix, Disney and Prime for everything else. Use the freeview apps to catch up.
If you've got a TV with the Freeview+ App, you can actually pause TV, or go back a little. Our Toshiba does that, but won't do Prime - only does Netflix.
The older Samsung doesn't have the freeview app, but you just have to go into the station's app to watch a programme that's just aired - it's usually on very soon after live TV.
Posted : 08/03/2021 3:16 pm
 stox
I find the opposite with Netflix. Spend 15 mins flicking through it, rarely find anything, and turn it off
Posted : 08/03/2021 3:23 pm
I cancelled sky a few years ago, if you have a dish fitted and it's not sky Q (although i'm behind on sky tech so that might still have a dish) then you get the freeview channels through the box anyway. We just watch the terrestrial channels ont he sky box with no issues (and have Netflix, amazon, disney on the tv as well mind).
Also i occasionally get a free month or so on the sky app so if there is anything interesting on (last time i used it was last summer for a show the gf wanted to watch) then I just cast it to the tv from my phone.
As an aside if you buy from adidas on their creators club thing they sometimes give a free month on sky.
Posted : 08/03/2021 3:29 pm
Changed my Sky subscription last month. Finally cancelled Sky sports (instantly saving 50quid a month), 'upgraded' to a SkyQ box for free, and I still get Movies (for a bargain price)
Should have done it years ago! Still got the old Sky+ box upstairs to watch non-subscription TV too.
Posted : 08/03/2021 3:37 pm
I just had a chat with them about the cost and they sorted out a deal for me which was astonishing.
I ended up getting everything bar Sky sports - including Sky Cinema, all in 4k, a new 4k box, 4k Netflix (that’s £14 on it own a month) and box sets, 45mb internet, phone line for £54 a month.
Amazon Prime is rubbish, Apple TV isn’t great yet and Disney, well we got it for free for a few days to watch the Mandalorian and nothing else we want to watch on it.
We think we got a bargain tbh
Posted : 08/03/2021 3:38 pm
Binned off sky before Christmas and have not watched live TV since. So I have also cancelled my TV licence as well . Kids seem more than happy with Disney, Netflix, and amazon and I enjoy saving a good few hundred pounds a year.
Posted : 08/03/2021 3:41 pm
My old Panasonic does both (as does the LG) – I’ve gone to Freeview though as CH4 isn’t available in HD on Freesat.
Mine does too, and FYI, CH4 is on Freesat in HD it's just been removed from the programme guide and doesn't get picked up via autotune, you can tune into it manually and it works just fine.
My Panny has 2 sat inputs, one is set to Freesat with the guide etc. the other is set for other channels and has CH4 HD on it, I just switch between inputs on the (very) rare occasion I want it.
Posted : 08/03/2021 4:04 pm
Watching with interest as plan to consider our options when the contract is up in May.
Posted : 08/03/2021 6:26 pm
FYI, CH4 is on Freesat in HD it’s just been removed from the programme guide and doesn’t get picked up via autotune, you can tune into it manually and it works just fine.
Good to know, thanks!
I think I'm OK with Freeview tbh but we have a place in Wales that gets S4C on Freeview instead of CH4, so I may use the satellite input on the Samsung there instead.
Posted : 08/03/2021 6:33 pm
Whilst that's true depending where you are you may not get anything close to the same selection.
Posted : 08/03/2021 6:41 pm
 pk13
@OP if you had skyQ you won't be plugging the feeds into your Freesat. Well you can but it won't work wrong LNB.
Posted : 08/03/2021 9:21 pm
I think I’m OK with Freeview tbh but we have a place in Wales that gets S4C on Freeview instead of CH4
In Wales we get both S4C and CH4 - but CH4 isn't in slot number 4.
Posted : 08/03/2021 9:38 pm
You do have to programme it with your choices, you can do this on the website. Strangely, it only shows you a small selection of what it has, based on what it thinks your preference is. But there is tons of proper genius material on there, if you know what to look for. In my opinion, at least. The Mrs and I watch a show then spent half an hour discussing it afterwards. Not much on Sky was ever deep enough to inspire that much thought.
Posted : 08/03/2021 9:41 pm
 bruk
Never had Sky as could never justify the cost. Recently refurbed the house and the builders were saying few people now put in cabling for Sky because everything just streams now. Don't watch football so the cost of Sky sports is mind boggling.
Posted : 08/03/2021 9:47 pm
You can get a smart freeview box that records ect, Got one for my mum at xmas. Sky seems pricey to me, always had freeview but have upgraded the pov spec Virgin for the last few years.
Posted : 08/03/2021 10:02 pm
E used to have the same problem... You just don't really know what your looking at.
But the Netflix thread on here has helped massively and now I'm much more open to giving something a try.
Chernobyl was possibly the only really good thing I've watched on sky - certainly that I can remember.
Posted : 08/03/2021 10:21 pm
Sky Arts has some of the best quality & most thought provoking content available anywhere. You’re missing out if you’ve never seen any of it.
Posted : 08/03/2021 10:24 pm
Sideload a Firestick?
Posted : 08/03/2021 10:26 pm
 stox
@OP if you had skyQ you won’t be plugging the feeds into your Freesat. Well you can but it won’t work wrong LNB.
I’ve got a sky+ box so should swap straight over i believe.
They did offer me a Q box for free as an incentive to stay but not interested.
Posted : 08/03/2021 11:08 pm
 pk13
You will be grand then
Posted : 09/03/2021 7:52 am
This is true. However, Sky Arts is now on Freeview, so you don't need a Sky sub to see it.
Posted : 09/03/2021 8:42 am
If you do like to record stuff my LG TV has just updated and it now has a series link option for USB recording.
Kinda helpful.
Posted : 09/03/2021 9:17 am
So does TLC. How will OP cope without Real Housewives and Dr Pimple Popper?
Posted : 09/03/2021 9:20 am
Tis true. I watched two arts documentaries last night, one on Sky Arts, one on BBC Four. The Sky Arts one was significantly more 'grown up' in tone. Was surprised how dumbed-down the BBC doc felt in comparison.
Posted : 09/03/2021 9:31 am
Even though I sub to most of the streaming services I still find most of the TV I watch is via SkyQ. It's partly the convenience of flicking through channels to see what's on + there are quite a few gems and Eurosport is a bonus (although I usually end up screaming as the bike race recording cuts off with 10km to go and end up watching the highlights on ITV4 anyway...)
Never really looked at Freeview to see how convenient it was, might actually try a month without using SkyQ to see if I miss it (although I think I'm still locked into a contract for most of the rest of the year anyway). Combined I pay over £100 a month just for TV stuff and over half of that is Sky 🙁
Posted : 09/03/2021 10:02 am
Just checked on my sub £10 a month Now TV sub and it has Sky Arts as well as a load of other channels built in. I know it doesn't have as wide a range of programmes on Now TV as Sky but I'll keep the change and simplicity.
If I ever want Sky Sports for big golf weekend or F1 it's a day, weekend or event pass.
Posted : 09/03/2021 1:18 pm
The 'new' Chromecast with Google TV is a great piece of kit. Gathers all the services into one place - just tell it what you want to watch and it finds it even its on a service you don't subscribe to.
Posted : 09/03/2021 2:13 pm
I might try this especially if it's on Freeview.
Posted : 09/03/2021 2:16 pm
 stox
Well I expected a call from Sky now I’m in the cancellation period but I didn’t expect it so soon!
They basically offered to recontract my broadband for 18 months (no thanks!), and give me a Sky Q box for the sum of £50 a month.
Thats twice I’ve had to tell them I’ve zero interest in a Sky Q box.
£50 a month is pretty much what my bill is now that I’m trying to reduce.
Is that it or will they try again?
Posted : 15/03/2021 4:30 pm
Also just cancelled. Did the email last week, had the call back today.
If we still get the free channels via the Sky box then that'll do.
I've tried plugging the cable from the dish straight into the TV but it only seems to find a subset of the Freesat channels (e.g. not the Scottish ones). I don't know if this is a limitation of the TV though (we've had a Freesat box plugged in previously with all the Scottish channels). The Mrs would like a new TV anyway but there doesn't seem to be a whole load with built-in Freesat or any way of checking they get all the Scottish channels.
Posted : 15/03/2021 4:37 pm
When we left Sky they basically told me to sign up to NowTV & Sky cinema monthly which I've tried to walk away from a few times and they always offer you a massive discount.
Our local Whsmiths has the NowTV boxes for £12.50 - all have a pass for either Sky Movies, Entertainment and Kids - 2 months for the former and the latter two for 3 months. Buying a box is cheaper than the 3 month pass...
Posted : 15/03/2021 4:53 pm
@Scotroutes - Do you need to reset the geographical zone of your TV? Maybe in a menu? Or get it to look for updated channels?
Posted : 15/03/2021 5:09 pm
@TroutWrestler = tried that but it only has "United Kingdom" 🙂  I'll muck about with it a bit more if I have to but I was hoping the Sky box might still give me the free channels even when my sub has ended.
Posted : 15/03/2021 5:16 pm
It will do.... it just won't pause/record. I would have thought that your TV should work OK though - may take a little fiddling.
We're 10 days in and not missing Sky one bit.
Posted : 15/03/2021 5:24 pm
Everyone who is hoping to get a better deal from retentions should login to their Sky Account BEFORE TERMINATION and tick the boxes that allow them to contact you via email/phone etc. It is no good waiting for them to contact you with a better deal if you have forbidden them from contacting you for "sales" reasons.
Posted : 15/03/2021 6:09 pm
 stox
Everyone who is hoping to get a better deal from retentions should login to their Sky Account BEFORE TERMINATION and tick the boxes that allow them to contact you via email/phone etc. It is no good waiting for them to contact you with a better deal if you have forbidden them from contacting you for “sales” reasons.
I can’t speak for others but I started the thread and I cancelled Sky because I don’t want to pay for a TV service we barely watch.
I’m happy to let them call me and make me an offer to stay but short of them giving me the TV for a fiver a month i’be no desire To sign back up.
Posted : 15/03/2021 6:35 pm
This thread prompted me to contact Sky this morning and tell them I was going to cancel.
I have been with them for ages, too long really.
The guy in the Retentions Team was very pleasant and came back with some good deals, but they just weren't good enough. So, I instructed them to go ahead with the cancellation.
Let's see if they come back within else in the next 31 days. If they don't then I will be looking at alternative streaming subscriptions and saving myself some money as well.
Posted : 15/03/2021 8:53 pm
