Joinerists - making...
Joinerists - making an internal door taller
I have a new doorway and I'd like to use a 'spare' door I have as it matches all the others - only issue is that it's about 10mm too short.
The door is made of solid dark hardwood (def not hollow/cardboard/eggbox) that has been painted.
Can I simply screw/glue a 10mm piece of timber to the bottom (or top) of the door and fill/sand it then paint the whole thing?
One complicating factor is that the floor has a slight slope to it so I presume this means I'd need to add the extra height to the top rather than the bottom allowing the bottom to be trimmed to match the floor.
Does this sound OK or am I barking up the wrong tree?
Posted : 29/09/2022 1:21 pm
Sounds fine. Generally I'd add to the bottom as it's better visually but 10mm probably isn't enough to impact on the symmetry. If you do want to add to the bottom then trim, just glue it without nails, or glue and screw but remove the screws before trimming.
Posted : 29/09/2022 1:26 pm
Yup. As above 👍
Unless you don't want to paint the door in which case perhaps you could add it to the inside top of the frame fairly subtly?
I wouldn't get out of bed for 10mm
Posted : 29/09/2022 1:31 pm
My initially thought was to add to the bottom but then thought that it might make trimming difficult - but I was going to glue and screw then remove the screws.
It's def being painted. I know 10mm isn't much, but it's in the hallway and I've spent quite a lot on renovations and I don't want a door that's a bit too short to be the first thing you see!!
(Also a hard surface so no carper to mask the gap.)
Posted : 29/09/2022 1:47 pm
 pk13
Put a strip on the bottom glue and screw it might be worth cutting the door down a tad more a 20 mm strip will allow for countersunk screw and less chance of hitting them if you have to trim it for floor carpets ect
Posted : 29/09/2022 2:27 pm
I was thinking of doing this also actually as the bottom of the door is currently a bit of a mess and I could give it a nice straight edge.
Posted : 29/09/2022 2:36 pm
[Possibly stupid question]
Does I need to fit a strip of the same type of wood?
Posted : 29/09/2022 2:37 pm
 DT78
wouldnt have thought its essential if its painted
I would have thought adding to the top was a bit better than the bottom. In case something gets caught under the door and could split the join (I have kids so sticks and stones are always in the hallway).
Posted : 29/09/2022 2:41 pm
Good point - the top is unlikely to hit something!
Posted : 29/09/2022 2:53 pm
If the grain of the door bottom and the strip are both going in the same direction then the type of wood you use isn't too important from a structural point of view.
Posted : 29/09/2022 3:28 pm
I'm a complete amateur at this, compared to the professionals above. I'd hang the door to fit at the top, then take a 20mm strip, lay it along the floor at the bottom and mark the door along the top of it. Then take the door off and cut/plane it to the mark (or a bit more if you need more clearance), fit the strip.
Posted : 29/09/2022 3:40 pm
Can't you just trim 10mm from the bottom of the surrounding walls?
Posted : 29/09/2022 3:50 pm
 pk13
Your more likely to see it at the top. Only grumpy people walk around looking at their shoes
Posted : 29/09/2022 4:35 pm
Add it to the bottom. Its easier to plane a strip with the grain all in one direction, no cross grain. It'll look less obvious too
Posted : 29/09/2022 5:20 pm
Put a 10mm strip in the top of the door frame.
(probably only work if the frame is relatively plain)
Posted : 30/09/2022 9:59 am
Can’t you just trim 10mm from the bottom of the surrounding walls?
Username continues to make sense
Posted : 30/09/2022 10:05 am
If the door frame is painted I’d look at lowering that, particularly if there’s an architrave you can remove and cut down.
Posted : 30/09/2022 11:35 am
There was a whole sub-genre of indie music devoted to gazing at ones shoes.
Op are Slowdive or My Bloody Valentine likely to visit and want to use that door?
Posted : 30/09/2022 12:45 pm
Or as a Swedish colleague once said to me: "How do you spot an extrovert Finn? He's staring at your shoes."
Posted : 30/09/2022 2:52 pm
Hang the door correctly at the bottom and then add the strip to the door frame at the top thus filling the gap
Posted : 30/09/2022 3:02 pm
If you really really want to do it properly, search YouTube for Bradshaw joinery. He did it recently to an unpainted door
Posted : 30/09/2022 5:31 pm
