I've just bought a ...
[Closed] I've just bought a 2nd hand laptop. What do I need to do?
I've just bought a laptop from an ebay seller of refurbished laptops.
A search by serial number on the Lenovo website shows that all drivers are available.
This PC > Properties shows that Win 10 Pro is activated.
Shall I run Windows 'Reset this PC' > 'Remove Everything'? Or should I format the disk and re-install from a USB?
Anything else I need to do?
Posted : 28/11/2018 2:54 pm
I’ve just bought a 2nd hand laptop. What do I need to do?
Run a file recovery program. Look for password files, financial data, and homemade porn for blackmailing.
Posted : 28/11/2018 2:57 pm
Shall I run Windows ‘Reset this PC’ > ‘Remove Everything’? Or should I format the disk and re-install from a USB?
Does it still have old data on it?  The previous owner may have done that already.
Personally I'd do one or the other of those - both should achieve broadly the same end result - purely from a paranoia perspective.
Posted : 28/11/2018 3:04 pm
As said, look for porn, duh.
Posted : 28/11/2018 3:19 pm
I love how utterly predictable this place is LOL.
I’d try turning it off and back on again as a start.
Then wipe it clean, then reinstall whatever software you want to put on it.
Posted : 28/11/2018 3:22 pm
Unless it already has one, install a SSD, then build from new.
Otherwise, if it boots straight to desktop rebuild it, if it goes through the normal new windows machine process don't bother.
Posted : 28/11/2018 3:28 pm
 toby
I would download a fresh installation USB drive (on another computer if feeling especially paranoid) and format / install from that. Not only do you then eliminate most of the remaining (admittedly slim) risk of anything nasty being left on it, but a fresh installation from up-to-date media appears to end up with more free disc space than running all the updates on an older installation.
Posted : 28/11/2018 3:29 pm
 Nico
Doesn't refurbished usually mean somebody opened the packaging and then changed their mind? In other words is it really used/second hand, or just a return? Not much chance of pron if the latter.
Posted : 28/11/2018 3:34 pm
That's what Disk Cleanup is for, but yes, agreed.
Posted : 28/11/2018 3:39 pm
 toby
That’s what Disk Cleanup is for, but yes, agreed.
True, but IME (tainted admittedly by a frustrating week of trying to get a cheap laptop with a 30GB drive usable), it's not as effective.
It also doesn't entirely remove the (slim) chance that an unscrupulous refurbisher has put a key-logger into the OS.
Posted : 28/11/2018 5:57 pm
I probably would have done a fresh install from the advice above... but I couldn't find a USB stick so went for the reset. I'll blame Cougar if I'm hacked.
Too late for the extra info now, but it's a 4 year old Lenovo X1, so definitely used and already has a SSD.
Posted : 29/11/2018 11:01 pm
