I've got Spotify Pr...
[Closed] I've got Spotify Premium and Chromecast Audio
10 Users
But I'm not thrilled by the sound quality.
I use an old Denon amp and Mordaunt-Short speakers which give very acceptable sound from the CD. The amp only has RCA inputs - nothing fancy like optical. My music is streamed from either Android phone and tablet or Windows PC using Chrome.
I like Spotify because I can stream at a reasonably high bit rate, it has most of the music I listen to and I can use the offline downloads for those times when I'm on holiday or away from wi-fi.
Apart from Spotify the only other music I listen to is 6 Music which i cast to the Chromecast.
My issues are that the music is a bit "closed in" and the chromecast sometimes comes over quiet, which might just need setting up a bit.
So, I'm thinking of adding a DAC into the mix, and possibly trying Tidal. As I say, I don't think the amp and speakers are letting me down.
Anybody else had the same issues and sorted it without a lot of fuss and cost?
Posted : 10/07/2019 7:06 pm
Have you got the Chromecast set to Full Dynamic Range?
Posted : 10/07/2019 7:16 pm
The Chromecast Audio does sound a lot better if you use its optical digital output into a DAC. Even cheapo DACs improve the sound a fair bit, and it can sound very good when a good DAC is used.
Posted : 10/07/2019 7:47 pm
Who would like to recommend the best value dac? Up to £150ish?
Thanks, I'll check (find how to) the settings.
Posted : 10/07/2019 8:15 pm
Thanks, I’ll check (find how to) the settings.
Go into Google Home, select the device, click the settings icon, and scroll down to sounds. If it isn't enabled it sounds awful with a proper amp / speakers.
Posted : 10/07/2019 8:24 pm
That might explain a lot. Thanks, Simon.
How are the Bogtrotters getting on these days. Haven't seen many photos of ladies' bottoms for a while 😎
Posted : 10/07/2019 8:51 pm
That'd be simonfb, not me. I don't think he was in a good way last I heard 🙁
Posted : 10/07/2019 8:55 pm
No, I know really. Terribly sad.
Posted : 10/07/2019 9:13 pm
Lots of decent stuff second hand in that bracket, including stuff like the Cambridge Audio Dacmagic or Dacmagic 100 (if you don't need a balanced output).
I run Spotify digital output from my laptop through a NAD 3045D DAC/amp to B&W speakers, and have to say it doesn't sound great. Tidal (at a minimum of 24-bit/92kHz) sounds a lot better to me, but the selection just isn't as good as Spotify and for this reason I often find myself frustrated with the service. No perfect solution yet as far as I know.
Posted : 10/07/2019 9:29 pm
Better off spending on a new amp with an integrated dac if the denon doesn't have one, alot less fuss, and a mini toslink to toslink cable.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F362240475737
https://www.ebay.co.uk/itm/Onkyo-TX-8050-130W-Network-Stereo-Receiver-Black/153528961140?hash=item23bf0a0874:g:~IIAAOSw3rtdBOHq
https://www.ebay.co.uk/itm/Yamaha-A-S501-HiFi-Separate-Integrated-Amplifier/223578863882?hash=item340e56b90a:g:7m4AAOSwQGVdIlDr
The 9010 got great reviews, but make sure it is the European model with optical inputs.
Posted : 11/07/2019 12:11 am
It's probably the full dynamic range option not being selected in the settings.
It makes a massive difference.
Posted : 11/07/2019 6:18 am
Its worth regularly checking the full dynamic range, mine was off last time I checked. Possibly since I got a replacement Chromecast a few months ago. Does make a big difference when using proper speakers.
Posted : 11/07/2019 6:43 am
@simon - thanks for that tip, I've just enabled it on mine and there's an obvious difference in sound, hadn't even realised the setting was there before!
Posted : 11/07/2019 8:57 am
Well, bugger me. I just looked for, and found Google Home on my phone. Now all my troubles are so far away...
Yesterday I was in Richer Sounds, seriously considering an expensive upgrade. Now, without having spent a single penny, I've got the sound I want. I have a richer sound without being poorer. Thanks Simon, the forum has done it again.
Excuse me now, I'm half way through Purple Rain and I feel a Wish You Were Here coming on. It's a bit loud in here.
Posted : 11/07/2019 4:52 pm
I play Spotify at the highest stream thru a logitech Bluetooth receiver. Sounds ace but BT does seem to be quieter than other sources. A DAC isn't necessarily going to give you more volume unless it's sone kind of dac with with an output pot.
Posted : 11/07/2019 5:49 pm
No, I've got masses of volume now I found the Google Home settings.
And that reminds me - must play Windowlicker again :o)
Posted : 11/07/2019 5:58 pm
Is this setting specific to the Chromecast Audio? I can't see a "Sounds" setting on my (regular) Chromecast.
Posted : 11/07/2019 6:01 pm
@cougar yes, and only with RCA output (it is enabled by default with optical output)
@bigjohn @toby1 no worries 🙂
Posted : 11/07/2019 6:44 pm
Bum.
OK, cheers.
Posted : 11/07/2019 9:09 pm
