That a house being built next to my place has scaffolding poles which rest against the side of my home?It is only six feet away but I don't think this going to be a very pleasant experience for myself.Any experiences or advice would be welcome.Thanks.
You should try living in a terraced house, both sides have had extensions (as have we).
As long as you don't add further annoyance, such as riding motorbikes all day, and not posting all over youtube, then you might get away with it.
Not without your permission I would have thought - where is the boundary? Have they gone over your land to erect the scaffolding?
IIRC its a complex area of law tho. When my building was done some of the scaffolding went right up to the next building but did not touch
They should have asked, out of courtesy but probably don't incase they're denied permission.
They're only using your house as a way of grounding the scaffolding securely, it won't harm your house.
Cirtainly should have asked first......
Atleast it makes shitting down their chimney a doddle.
Thanks matt,very grown up response
it won’t harm your house.
but it will mean much more noise transmission surely?
Have you got a party wall agreement?
They’re only using your house as a way of grounding the scaffolding securely, it won’t harm your house.
If it's resting on the building there is a good chance of rubbing, if it's bare metal against the building there's a good chance of rust stains.
I'd have a word.
I,m in an end terrace new build.I think I,m in for a couple of months of noise.
Noise you can't do anything about - disturbing or damaging your property you can.... First off have a friendly chat with the builder or owners. As mmcd said - is there a party wall agreement?
Is there any protection between the wall and the scaffold pipes?
If it's the ends of the pipes,vibration from structure could leave marks on your wall.
Oh and , They should have asked.
Thanks chaps.I'll wait and see what happens.
As mmcd said – is there a party wall agreement?
wouldn't there have to be a party wall for that? doesn't read like there is.
but they should have asked, although my experience of scaffolders is getting them to do what you actually want can be a challenge...
As there isn't a party wall, I would guess very unlikely.
You're going to wait until what? Some damage happens?
Wonder round and ask them to move it. There's nothing in it for you and frankly nothing in it for them either. The scaffolders are likely just being lazy. The last thing the site foreman would need is you coming piling in for reparations to your house. He'll just call the scaffold co and make them move it.
I presume there’s protective, plastic end-caps over the scaffold poles that touch your wall? If not, I’d insist on them being fitted - even if it means they have to move the poles - common courtesy and they should have asked before starting.
No it isn't acceptable. Your property doesn't exist to provide support for someone else's scaffolding.
And you don't need to have a shared wall for a party wall agreement.
Thanks chaps.I’ll wait and see what happens.
If you don't speak to them now they won't know you're concerned, then they won't be concerned. I'd rather them make sure they don't cause any damage rather fix damage later.
tell them to move it.
Is it ever acceptable to ever use third person pronouns?
You don't have to have an actual party wall to require a party wall agreement. The boundary is enough.
It's social housing,I'm not a home owner.Its my social housing provider that's commissioned the new builds.Their attitude is suck it up and go somewhere when the news gets unbearable. Complaints about bad practice fron builders only results in further problems.I guess I need to just hope there finished soon.Thanks for your replies.
I thought that the OP had enough problems without me calling down the wrath of the grammar gods over his abuse of a reflexive pronoun. Ordinarily though, such a transgression would be completely unacceptable.
OP, if it is your landlord doing this to their own building, I don't think there is much you can do unless your accommodation is rendered uninhabitable.
footflaps,how did you cope with the disturbance and inconvenience?I,m finding it very difficult after weeks of problems.
