[Closed] iOS 15
The web address bar is going to take some getting used to (down there ⬇️ on my phone and up there ⬆️ on my iPad).
Posted : 21/09/2021 11:06 pm
I’ve just upgraded and found the same thing…fortunately there’s a button in the settings to revert back to normal.
Apparently the new tab thing at the top of the screen was too much to ask for
Posted : 21/09/2021 11:14 pm
if you check in 'settings - safari - tabs' you change it back to a single tab at the top. I've done that just to make better use of screen space.
edit - mtbqwerty gets there before me
Posted : 21/09/2021 11:23 pm
Ah thanks for letting me know, I’ll have a play around with it tomorrow when not so tired
You can turn it off from safari itself. In the nab bar, tap “aA”, it is one of the options there.
I have turned it off. Annoyed me that the search results are still shown with the first at the top of the screen. If the aim is you don’t have to reach up, it fails for that reason.
Posted : 22/09/2021 8:32 am
I’m quite liking the address bar at the bottom, but the revised tabs seems to make very little sense. Why take something that was compact and useful and split it out over such a wide area? I see you can now group tabs, but that’s not too much use for me personally
Posted : 22/09/2021 8:42 am
 igm
Ooooh - there’s a “desktop website” button in the Aa bit too.
I wonder if that sorts the issue where someone’s website isn’t iPhone compatible?
Posted : 22/09/2021 9:08 am
That’s always been there.
Posted : 22/09/2021 9:16 am
I'm interested in the new 2FA functionality in Keychain. Has anyone set it up? Is it straightforward? In a situation where you already enabled 2FA do you just turn it off and start again?
So many questions.... 🙂
(if it works smoothly probably I will bin 1 Password. But I do like it for generating passwords with words...)
Posted : 22/09/2021 9:52 am
Yeah, just setup 2fa again. The old codes won't be valid anymore.
I suspect I'll keep using the MS Authenticator app as it integrates with the MS auth flow so you get a notification instead of needing to enter a code.
So far my killer feature is being able to let Blink send me notifications (for example, your garage is being broken into) at 3am when Do Not Disturb is on.
Posted : 22/09/2021 12:16 pm
Actually just set up a 2FA account in Passwords. I take it back, as they go on the cloud keyring I get to set it up on my phone and then it autocompletes on my laptop (with touchid).
Posted : 22/09/2021 12:20 pm
Updated mine last night, and now this place is a Christmas Tree of adverts 🙄
It had always been ok to use STW on my phone due to the lack of adverts
Posted : 23/09/2021 7:34 am
I'm hardly seeing anything (adverts that is) on my phone
Posted : 23/09/2021 10:33 am
Updated last night. Seems good, like the Safari improvements.
There are now notifications when you leave home without something an AirTag is attached to (wallet for example) which is pretty cool.
Focus mode would have been really good when I used to use Zwift on my iPad! Will have a proper play around with it later.
Posted : 23/09/2021 1:26 pm
Tags for notes will be handy. It continues it trend of ios making 3rd party apps less and less appealing as their functionality is incorporated into IOS.
Posted : 23/09/2021 2:57 pm
Copy and paste text from an image or live in camera is neat, if not amazingly accurate yet.
Quite like being able to swipe between tabs, so leaving the address bar at the bottom for now.
Posted : 23/09/2021 3:02 pm
 igm
Doesn’t quite work for me yet. I carry two iPhones (one work) and the works one goes into car mode automatically as per work instructions. At which point my personal iPhone tells me I left my works iPhone behind.
Posted : 23/09/2021 4:38 pm
Has anyone else started finding copying and pasting text a faff since updating?  Particular any text that extends beyond one line
variously haphazard and impossible on STW -(I just gave up a re typed someone else’s post in order to quote it on another thread)  not really tried it on other sites
Posted : 25/09/2021 4:14 pm
Copy and paste an image from iMessage to WhatsApp? 😂 I get a great local file address, no image.
The address/search bar at the bottom was very weird in the beta. Glad the top/bottom option was added into the address bar menu.
Posted : 25/09/2021 4:18 pm
Actually - to update that query - the issue seems to be trying to copy from the most recent post. Anywhere else on a thread seem fine but on the post right above the reply box highlighting text seems to go phut.
Actually – to update that query – the issue seems to be trying to copy from the most recent post. Anywhere else on a thread seem fine but on the post right above the reply box highlighting text seems to go phut.
Seems ok I think?
Posted : 25/09/2021 7:01 pm
Not sure about the address bar yet, I’ll try it at the bottom and see how it goes.
Pull to refresh in Safari finally though, which is nice.
Posted : 25/09/2021 7:03 pm
Weird. Maybe it’s just me then - anywhere else on the page it’s fine but on the last post on the page all sorts of things go wrong. You can highlight a word but if you try to pull the little tabs to extend the selection it either refuses, scrolls the page instead , or seemingly selects the whole screen
Posted : 25/09/2021 7:08 pm
Just tried it with the text above, and it worked perfectly. I had c’n’p’d text since updating the other day, and I can’t say I’ve noticed any issues since, thought I’d have another go, just in case.
Posted : 26/09/2021 11:33 pm
