Insulation between ...
[Closed] Insulation between floor batons (Celotex) Q
Batons are 38mm deep screwed into poured concrete floor. Client has bought 25mm Celotex as he only had a choice of that or 50mm. Will the half inch or so air gap between Celotex and my oak floor being nailed to the batons make any difference?
Posted : 18/10/2012 9:02 am
Was insulation laid within the concrete floor? If so would just some fibre board underlay without the batons be easier?
Posted : 18/10/2012 9:10 am
What is the insulation trying to achieve? Is it the only floor insulation there is? Is there a vapour control layer? Is there a DPM incorporated into the floor make-up?
Posted : 18/10/2012 9:13 am
what mikey said!
#insulationwolf
Posted : 18/10/2012 9:15 am
if it were me, and not withstanding the above, I'd put the celotex so it had the gap between it and the concrete not it and the floor to let air circulate a bit over the concrete.
Posted : 18/10/2012 9:17 am
The problem is that if you create a dew point where the batons are, water will settle around the batons and will eventually rot them away. You will need to lay a vapour control layer over the battens to prevent internal moisture getting through to the subsrate.
Posted : 18/10/2012 9:23 am
Ah, yes, well, y'see. Yes, there is a DPM within the concrete. It is then painted over with another waterproofing resin. So moisture isn't going to be a problem (not one I'll be snagging for free in a year's time anyway ๐Ÿ˜€ ). Concrete was poured 2 years ago. I have no idea what the Celotex is trying to achieve. Only that the client wants it and I'm being paid to cut and fit the shite.
I might just fire a dozen cans of expanding foam in there. ๐Ÿ˜†
Posted : 18/10/2012 9:36 am
do not get your spray cream and expanding foam mixed up
Posted : 18/10/2012 10:00 am
