Installing rads in ...
[Closed] Installing rads in an old system advice
Can you help. This is the picture. I need to replace some 'missing' rads that are part of a functioning but in need of repair CH system.
There are two missing.
One has the remnants of the old valves still attached and not sealed in anyway.
The other has a sealed off pipe ( I assume water is flowing to it?) and the other end is the remnants of another valve, also un sealed.
Question is how do I tell the direction of flow if I fit new rads? I assume rads have an input and output?
The system works, and is controlled by a standard room stat, though they need constant bleeding.
I am very competent with normal plumbing building DIY etc. I can make solder joints and have a good selection of tools, though I've never attacked CH
I assume I just need to establish which end the water flows into, and fit standard valves that end?
Posted : 20/03/2013 7:09 pm
Radiators aren't direction, some thermostatic valves are, but just use ones which aren't and you'll be fine. You normally fit two valves, an isolation / flow restriction valve at on end and a thermostatic valve at the other.
Posted : 20/03/2013 7:53 pm
Well that would make the whole thing easy.
So a bi directional thermostatic valve can be fitted at either the flow in or out end?
Posted : 20/03/2013 8:04 pm
Yep. The uni-directional ones have an arrow on the body for the flow direction.
Posted : 20/03/2013 8:07 pm
http://www.screwfix.com/p/pegler-terrier-ii-white-chrome-trv-connector-15mm-angled/23130
White and chrome finish. Offers frost protection. Positive shut-off. Approved to EN 215.
Wax Sensor
Bi-Directional Valve Body
Connector or Elbow Option
Double O Ring Seal
5 Year Manufacturer's Guarantee
Posted : 20/03/2013 8:09 pm
And for the other end (for balancing the system):
http://www.screwfix.com/p/verona-angled-radiator-valves-15mm-pair/37800
Chrome-plated brass finish. Positive shut off.
High Quality Chrome-Plated Brass
Posted : 20/03/2013 8:10 pm
