How to silence my s...
[Closed] How to silence my screaming roof bars?
Alright people,
Took the roof box off for first time in a long time, drove 5 hrs to Cardigan and back and the whole way there, at any speed >60mph the most mind-bendingly annoying high pitch moan emitted from what sounded like the front roof bar.
Is this normal?
Any way to shut it the @&()£ up? 🙂
Thanks car persons.
Posted : 19/09/2011 7:20 pm
Sell the car and buy a van. Not the most economical option but it's an option. 😯
Posted : 19/09/2011 7:23 pm
I you aren't using them then take them off. Not only will it stop the noise but it will save you a suprising amount in fuel too!
has an end cap come of the bars?
Mine did this and whistled all the time.
or take them of or drive slower 😉
Posted : 19/09/2011 7:25 pm
We had this on an old Escort van we had, in the end we zip tied some pipe insulation across the bar and this put a stop to it.
Posted : 19/09/2011 7:27 pm
You can buy roof bar fairings which will solve the problem.
Posted : 19/09/2011 7:29 pm
Let your wife ride inside the car?
Posted : 19/09/2011 7:40 pm
My aerobars whistle when they're wet. Overspray from the windscreen wash is enough to set them off. No, I don't know either.
Posted : 19/09/2011 7:56 pm
And before you lot start, I mean these:
Not these:
You're not funny, you know.
Posted : 19/09/2011 7:58 pm
We had some Thule's that used to howl - they had a slot underneath to allow variance in car model width. I taped these up and it stopped.
Posted : 19/09/2011 8:11 pm
Are they like the ones in that picture? If so, putting the rubber strip in makes a huge difference.
Posted : 19/09/2011 8:12 pm
Ooh - cunning, I'll check that tomorrow. Ta.
Posted : 19/09/2011 8:17 pm
Pipe insulation!
Posted : 19/09/2011 8:21 pm
I had this with the Thule aeros. Run some tape along the underside of the bars to cover the channel that is visible. It makes them much quieter.
Posted : 19/09/2011 8:49 pm
I've always just ignored this, but thanks for giving me some ideas on what to do.
Every day is a school day on here!
Posted : 19/09/2011 8:51 pm
I have some aero types, forget the make but not Thule. They have a slot in the top into which you slide the Thule bike carrier, filled with a bit of soft rubber which made it a little hard to slide the carriers in. So I removed it, and listened to a horrible whistle for a day. Following day I put it back, put up with the fiddly fittings and it was fine.
Posted : 19/09/2011 9:10 pm
Cover the slots on the bottom. Either with the plastic strips that you get with it or if you have lost them just use tape like me.
Posted : 19/09/2011 9:16 pm
