Honda Accord Yellow...
[Closed] Honda Accord Yellow Light Of Death - Traction Control light??
Hi
My father has a 2007/8 Honda Accord diesel estate with a permanent traction control light (VSA light?)
He lives in the middle of darkest Norfolk so there are no decent specialists to get it checked it out with. A new "TCS unit" is apparently about £2k.
Is there any way of knowing whether it's definitely this controller box thingy?
Ta
Posted : 18/11/2015 12:58 pm
My bet would be a faulty sensor. Why not take to a deserted wet car park and try and give the traction control a bit of a test ?
Posted : 18/11/2015 1:02 pm
Drive on a load of mud/field/etc, put your foot down and see if it wheel spins would be the simple answer. If the car limits power you still know its working.
Posted : 18/11/2015 1:03 pm
Presumably if only one sensor is dead it would only spin one wheel?
I think my dad's more worried about it failing it's imminent MOT based on the light, than anything else!
Posted : 18/11/2015 1:06 pm
Sorry, yes I see your point re testing the controller!
Posted : 18/11/2015 1:08 pm
The VSA light has been on on my honda accord tourer for around 5 years. The VSA works and it's just a sensor issue within the control box or something like that. The box can be removed and reprogrammed which costs around £150 but obviously it needs to be removed, sent away, reporgrammed, then returned which would leave the car off the road for a while.
[i]I think my dad's more worried about it failing it's imminent MOT based on the light[/i]
Well that depends on how well your dad knows the tester but it technically should be a fail. Whether it is or not is another matter.
Posted : 18/11/2015 1:16 pm
As already stated probably just a faulty sensor which will be either the sensor it self of the ring that it is reading. A good fault code reader would tell you which wheel is creating the fault. Swapping sensor from a good wheel to the one that was showing a fault will tell if it's the sensor or ring.
Posted : 18/11/2015 1:22 pm
You can get cheap code readers on ebay, that'd be my first step. Get the fault code. In general a wheel sensor is much more likely than the controller.
Posted : 18/11/2015 1:52 pm
