Homeopathic bike re...
[Closed] Homeopathic bike repairs
Since homeopathy is now available from the NHS and therefore clearly an effective, scientifically proven approach to healing, I'd like to hear your tips for applying homeopathy in the workshop. Here's one to get you started.
Punctures: to treat a puncture, take a small thorn and dissolve it in an Olympic swimming pool of water. Take one drop of this solution and dissolve it in another Olympic size swimming pool of water. Repeat x 7. Now take one drop of the resulting solution and drip it into your tyre valve. Repeat 3 times a day until the symptoms have gone.
Posted : 23/10/2013 1:04 pm
I find dabbing a dropper of Bachs rescue remedy on my spokes when Im wheel building helps them unwind.
Posted : 23/10/2013 1:06 pm
 iolo
All pharmacists here in Austria are trained homeopaths.
It's part of their degree.
Posted : 23/10/2013 1:07 pm
You forgot that you have to knock the vial of [s]water[/s] medicine on a horses saddle - you can't miss that out otherwise it won't [s]convince idiots with more money than sense[/s] work.
Posted : 23/10/2013 1:09 pm
Lots of people I know have imaginary problems with their bikes, fixing them with homeopathy makes perfect sense.
Posted : 23/10/2013 1:10 pm
Or there could be my current GPs approach - problem with bike? Don't ride it.
Problem solved.
Posted : 23/10/2013 1:25 pm
[i]All pharmacists here in Austria are trained homeopaths.[/i]
surely only one of them needs to be trained and the rest just pick it up by being in a very dilute gas mixture that they all breathe?
Posted : 23/10/2013 1:27 pm
It used to be a whole term's course, but they've now cut it back to just one minute of teaching to make it more effective.
Posted : 23/10/2013 1:33 pm
I do have the occasional repair where I can find no explanation so I dismantle things, clean them, and put them back together and that fixes the problem.
I did have one customer tell me to stop truing a wheel while I was talking to her, as the spinning spokes were affecting her energy field.
Posted : 23/10/2013 1:37 pm
Really? Ive just looked through the curriculum for the Diplomstudium Pharmazie at Vienna University and there's no mention of it.
Posted : 23/10/2013 1:39 pm
It's there, just in the undetectably small print.
Posted : 23/10/2013 1:40 pm
i know of at least two riders who would benefit from being able to spend money on something that would at least do no harm.
Posted : 23/10/2013 1:44 pm
Ohh!try smearing some tiger balm on your discs, they should give off pleasing decongestant aromas when they get warm on the long descent.
Posted : 23/10/2013 1:47 pm
now you're confusing herbal remedies with homeopathy. Not the same thing s-b-h.
EDIT: But then so was I with the Bachs thing ๐Ÿ˜ณ
However, Bachs is still quackery, if not homeopathy.
How do the Remedies work?
The Bach Flower Remedies is a safe and natural method of healing. They gently restore the balance between mind and body by casting out negative emotions, such as, fear, worry, hatred and indecision which interfere with the equilibrium of the being as a whole. The Bach Flower Remedies allow peace and happiness to return to the sufferer so that the body is free to heal itself.
Tiger balm on the other hand is eye-watering orsumness.
Posted : 23/10/2013 1:51 pm
I've explained to my derailleur that its probably allergic to wheat.
Posted : 23/10/2013 2:04 pm
Try smearing some tiger balm on your discs,
Well, if that's what you call them....
Posted : 23/10/2013 2:06 pm
I know a few bike mechanics that use herb supplements ,maybe it helps them with fixing bikes. ๐Ÿ˜‰
Posted : 23/10/2013 2:10 pm
I find when it comes to getting gears to index properly, the holistic approach, although time consuming, works best. Start from scratch and fettle everything.
Posted : 23/10/2013 2:53 pm
Posted : 23/10/2013 2:55 pm
Not to be too pedantic but - big difference between "holistic" and "homeopathic".
There are people who use the term "holistic medicine" to mean alternative medicines (incl but not limited to homeopathy) but it is not actually correct.
Posted : 23/10/2013 2:57 pm
@ soobalias - homeopathy in fact DOES do harm - because it means that people use it in stead of actual, effective treatments. Often the person who ends up being harmed is someone vulnerable - a child or a very gullible partner.
Posted : 23/10/2013 2:59 pm
I wouldn't say your too pedantic, just enough to be annoying ๐Ÿ˜€
Posted : 23/10/2013 3:01 pm
[i]I wouldn't say your too pedantic[/i]
*nngghhhh*
Posted : 23/10/2013 3:03 pm
