'High Efficien...
[Closed] 'High Efficiency' USB mains chargers
Having recently heard all sorts of horror stories about dodgy third party mains chargers that catch fire and/or explode I'm seeking recommendations from the STW collective on a USB mains charger that is safe and reliable. I would like to be able use overnight and wake up in the morning.
It's to charge a Lezyne Power Drive XL light and should output 2 Amps - what Lezyne calls 'High Efficiency' charging which charges faster. Should also have a reasonable length cord (about 3ft/1mtr if possible) with a micro USB at the end. I'm looking for something simple so don't need multiple device charging capability. Would be helpful if recommendations could include links.
Posted : 04/06/2014 11:09 am
Apple charger? Especially ones for the iPad as they are capable of the higher current output.
Rachel
Posted : 04/06/2014 11:11 am
Just about any smartphone/tablet charger will be 2A.
I picked up a few that are mains-USB socket, then USB lead of your choice. Cost maybe a fiver each. Got a 12V car one too, that's also 2A.
Posted : 04/06/2014 11:30 am
Maplin sell generic ones. I have one that has two sockets, 1A and 2.1A.
Posted : 04/06/2014 11:34 am
Rachel
I thought iPad chargers went at low amps hence why mine can't charge my phone to save itself..
Posted : 04/06/2014 12:46 pm
This should do it
https://www.modmypi.com/5v-2A-modmypi-raspberry-pi-power-supply
Have you managed to get the charging LED to blink blue when connected up to a high capacity USB PSU?
I built my own using a bench top power supply and experimented with shorting the D+ & D- lines together and by using a 50 Ohm resister which should indicate to the chargeable device (the light) that there is a high capacity PSU available. No luck. It stayed on about 0.93A instead of switching to almost 2A.
I wonder if they have a custom method of signalling the presence of a high capacity PSU.
Posted : 24/09/2014 5:06 pm
Squirrellking. Ipad changer charges my phone double quick.
My phone charger struggles with the ipad.
Posted : 24/09/2014 9:48 pm
