Help fix my heating...
[Closed] Help fix my heating - 2 out of 7 radiators stone cold, other 5 piping hot
I haven't seen these notes but the problem I've had in the past is finding "the radiator that heats up first".
Is there a way of finding out that is better than the guesswork of running round house and feeling the rads?
Maybe your system is already well-balanced??
The next step is to measure the flow and return temperatures when the system has warmed-up and adjust the lock-stops to achieve the desired temp drops.
Posted : 18/03/2013 10:47 pm
Hooray, the rad in the hall that's never worked is now nice and warm!
Thanks for the notes/tips.
dooosuk also passed on this vid which was very handy.
Posted : 19/03/2013 11:32 am
Glad someone else has had success 🙂
Posted : 19/03/2013 11:58 am
Thanks for the info on balancing, have just picked up some cheap thermometers off ebay to do the temperature balancing.
If you can get them for a good price I would recommend the Danfoss TP5000 Si-RF, they are quite versatile, can be used as a standalone stat or programmable timer/stat. Paid £60 for one off ebay.
Posted : 19/03/2013 12:00 pm
are the notes anything else other than setting an 11-12 degree temp drop over your inlet and outlet pipes ?
I guess im curious - as i have mine set up as above just wondering you know.
how ever i did do it in the order of closest to boiler - to furthest then checked them all again the next day
Posted : 19/03/2013 12:02 pm
Could I please have a copy of the document?
I balanced mine by running around the house making sure everything warmed up roughly at the same time, but it sounds like I could make things more efficient.
sam AT gettome DOT com
thanks.
Posted : 19/03/2013 12:11 pm
That's pretty much what's in the notes...however I didn't set mine this way. I just backed them off closed 1/4 turn as in the video and as the radiators fired up just left it at that.
Posted : 19/03/2013 12:12 pm
oh ok , i just wondered as bears the expert im just a multi dicipline engineer 😉 ( jack of all master of none)
Posted : 19/03/2013 12:21 pm
 Bear
Trail - nope simple as that 11 deg unless modern condensing boiler then 20 deg.
I got fed up with explaining the process every time I wrote a report fro the NHBC about why the latest heating system wasn't working so came up with an explanation of how and why etc.
Posted : 19/03/2013 12:28 pm
sorry to ressurrect an old thread but can anyone who has a copy of the legendary balancing notes please send them to me? Thanks
martindmail-singletrack AT yahoo DOT co DOT uk
Posted : 17/04/2013 8:56 am
got this now, thanks dooosuk
Posted : 17/04/2013 12:33 pm
Page 2 / 2
