Hardwood floor fitt...
[Closed] Hardwood floor fitter near Tunbridge Wells
[#3183387]
Can anyone recommend me a decent hardwood floor fitter near Tunbridge Wells?
I'm looking for fitting only if possible. If not, a decent supply and fit company will have to do.
Many thanks
Posted : 26/09/2011 10:49 am
Wierdly enough, I was about to post the same question!!??
That is tres freaky... 😯
Posted : 26/09/2011 10:51 am
I've heard good things about[url=www.naosfloors.co.uk]Naos Floors [/url] in Tonbrodge although not used 'em myself, yet. Met a guy from them called Dave Ryan who seemed to know his stuff.
Posted : 26/09/2011 11:05 am
Thanks for that Nobby.
But they seem to be a bit out of my price range. They seem to start at about £60 sq metre supplied and fitted.
I'm looking for about £40 - £50 per sq metre.
Posted : 26/09/2011 7:46 pm
2x jobs in the same spot and deadlydarcy might even travel from [s]Oirland[/s] Brizzle.
Posted : 26/09/2011 7:53 pm
2x jobs in the same spot and deadlydarcy might even travel from Oirland Brizzle.
Well la de ****ing la 🙂
If you'd asked three months ago, I'd have been biting your hand off. Sorry, bit busy right now...boss. But, £40-50 per sqm supplied and fitted? I'd struggle even at mate's rates. Hope you find someone - if you have any questions in the meantime, fire away.
Posted : 26/09/2011 8:11 pm
bit busy right now
good to hear.
Posted : 26/09/2011 8:12 pm
Darcy,
What is the going rate for fitting per sq metre? I was thinking along the lines of about £18? Is that a bit optimistic?
When I said hardwood, I should of been clearer, I would be happy with engineered. Not wanting laminate though. That leaves about £30 per sq metre for the flooring.
I am close or do I need to up the budget?
Thanks for the help.
Posted : 26/09/2011 9:10 pm
I suppose when you put it like that, £50 doesn't seem too bad. If it's pre-finished, then £20/sqm-ish is about right for fitting. A lot of my work involves finishing also, so more ££. £30/sqm for timber will get you something decent off the Internet. Will it be glued (concrete) or nailed? Doors? Thresholds? Fireplace to frame? Etc etc.
Posted : 26/09/2011 9:20 pm
Thanks again Darcy.
Is it worth paying for the branded stuff - Kahrs, Junckers? Or the cheaper unbranded stuff? Can you recommend any websites?
The fitting should be pretty simple, but it will part of a much larger renovation, central heating, plastering etc. I'm still scoping out my options.
Posted : 26/09/2011 9:40 pm
No worries...
I don't think there's any need to go for the Kahrs or Junckers...unless you have to money. Most of theirs is click together anyway...and I think floating is a No-no if you want a proper job. As far as websites are concerned, I don't use any as I have all my suppliers down here in Brizzle/Baaath area.
Just hunt around - you should probably be looking for something along the lines of:
Structural thickness (18mm or more)
Wear layer of greater than 3mm (6mm typical)
If pre-finished, go for oiled - much easier to maintain yourself in the long run. Factory finished lacquers are cheap and easily marked.
Go for a fixing method that fixes the floor to the sub-floor i.e. by gluing or nailing if a timber subfloor (this might leave you paying a little more than £18/sqm for fitting, but you never know).
Get 2 or 3 quotes and use the guy who sounds like he knows what he's talking about - having said that, I get work so not everybody does that obviously 🙂
Posted : 26/09/2011 10:11 pm
what would we do without floorstyle consultants 😉
Posted : 26/09/2011 10:13 pm
All free of charge too.
Posted : 26/09/2011 10:17 pm
