Guide to road cleat...
Guide to road cleat (Shimano) set up?
[#12935853]
http://www.stevehoggbikefitting.com/bikefit/2011/04/power-to-the-pedal-cleat-position/
I’ve some new cleats for my road bike. The shoes were second hand and I just left the old cleats in their original position for the last two years. I started looking for a simple guide on there they should go and disappeared down a roadie shaped rabbit hole.
Thinking of ball of foot minus the dimension in the link above. I know my heels are a bit inward but with 6 degrees of float I’m assuming that is less critical.
Posted : 21/08/2023 1:54 pm
If you were comfy with them already then just put them where the old ones were.
Posted : 21/08/2023 2:01 pm
Kryton57 reacted
My "method" is to push the cleats as far back as they'll go on standard shoes and then rotate a little bit to allow for my (un)natural foot position - I still think having your natural position in the centre of the float is sensible, unless it makes you hit the chainstays all the ime
Posted : 21/08/2023 2:07 pm
 Jamz
My “method” is to push the cleats as far back as they’ll go on standard shoes and then rotate a little bit to allow for my (un)natural foot position – I still think having your natural position in the centre of the float is sensible, unless it makes you hit the chainstays all the ime
Same for me, although I set mine dead straight. If you're running cleats with float then you probably need to fuss too much.
Posted : 21/08/2023 2:57 pm
