Granny and the turb...
[Closed] Granny and the turbo
Is there a minimum output for registering on a turbo.
The other day I was in the granny and spinning relatively slowly and it seemed to confuse the resistance and read 0 power output. If I sped up the rpm it then appeared to work.
It’s a “Drivo”.
I rarely use the thing so can’t say if it’s ever worked before.
Posted : 23/01/2021 2:57 pm
I have a drivo. It'll register well under 50w, no idea how it'd "cope" with less than 20 or so but I've never seen zero registered when pedaling
Posted : 23/01/2021 4:43 pm
My 7 year old son has ridden my Drivo on Zwift and it quite happily registered his power output of circa 20W or so.
Posted : 23/01/2021 4:48 pm
Genuinely disappointed this isn’t about Gran dropping watt bombs in a Zwift Crit Race
Posted : 23/01/2021 4:49 pm
Definitely a misleading clickbait title!
Posted : 23/01/2021 4:57 pm
Somewhere there will be a table showing the power range at different cadences for the Drivo in 34T and 50T rings at least. Is there a Drivo user Facebook group?
There is a Direto group and iirc from the table, 34/18 gear gives a range of something like 84-484W at 80-100rpm.
When I cool down in easy gears, the power can easily go sub 50W, but a quirk I've noticed is the cadence reading drops to ~50% of actual below ~60W if I'm spinning at my normal 90ish. If I slow down my cadence to ~70 in such situations, the reading on Zwift then looks normal again.
Posted : 23/01/2021 5:02 pm
 Muke
I though this was going to be about
Posted : 23/01/2021 5:08 pm
I don't think it's so much a out the power in your situation but the doped of the rear wheel (or 'wheel' if it's a wheel off turbo). In granny the rotation of the rear wheel is so slow for a given crank rpm I would guess it doesn't work well with their resistance algorithm?
Posted : 23/01/2021 5:57 pm
If you're doing intervals and suddenly go from 250 watts to 125 say it will sometimes register 0 for a few seconds as the erg mode catches up on my Drivo... legs are going round so assuming some power is coming out if them😉
Posted : 23/01/2021 9:04 pm
