Fridge getting too ...
[Closed] Fridge getting too cold?
Even with the dial turned down to 1 we are getting fizzy drinks can exploding inside the fridge, bottles of tonic doing the same - doesn't seem to matter if they are in the fridge or in the door
It's a built in fridge. There is a built in freezer too but that isn't next to the fridge
Anything obvious I can check before I call someone out?
Posted : 18/03/2018 1:18 pm
when our under warranty motorhome fridge went temperature wonky the tech support guy said step 1 was a thermocouple and sent us a new one - luckily on the motorhome fridge is was a bolt on/plugin job but it fixed it, can you find a diagram on tinternet and see if it could be the same
my other idea is to check if it feels like the dial is actually doing something/connected ok
Posted : 18/03/2018 2:26 pm
Yes, try turning up the dial to make it warmer, not down.
Posted : 18/03/2018 4:38 pm
Is it in a cold place? Fridges in garages or cold houses can be too cold as they cannot cope with ambient temps too low.
Posted : 18/03/2018 4:53 pm
The thermocouple (can look like a couple of wires twisted together and wrapped in insulation - because that's what it is) needs to be in a coldย  place in the fridge.ย It's like the thermostat. If it's been dislodged, and it's always warm the fridge will just keep cooling and cooling.
Posted : 18/03/2018 6:09 pm
Put the fridgeย in the oven?
Posted : 18/03/2018 6:58 pm
As above try the opposite end of the numbers before anything else...
It's probably degrees rather than 1-5 in coldness
Posted : 18/03/2018 7:47 pm
You know who to call...
Posted : 18/03/2018 7:52 pm
