Freesat cable route...
[Closed] Freesat cable route-advice please
I've currently got freesat in my living room with two leads coming off the dish for a double tuner.I want to put another tv in the bedroom and run a third cable to another freesat box.is this possible does anyone know?
Posted : 19/06/2011 10:00 am
My parents have 3 cables coming out of a single socket, iirc it's a single socket that had an extra 2 holes drilled in it, doesn't look quite as tidy but then is hidden behind the telly. The guy did it when they were having the dish installed so I would say it is possible, just probably worth having a professional do it!
Edit: just re-read your post and seen you mean a different room. Should be possible I guess as it's the same principle as above but 1 leads just going to a different room
Posted : 19/06/2011 10:06 am
If there are any spare outputs on the dish it should just be a case of running another feed from it to wherever you want the extra box.[url= http://www.satcure.co.uk ]www.satcure.co.uk[/url] has some useful info, most of the Sky info is the same for Freesat.
Posted : 19/06/2011 10:30 am
Spot on,cheers for that
Posted : 19/06/2011 11:55 am
