Umming and ahhing about getting a HD TV with built in Freesat tuner. I've never had more than the 4 terrestrial channels before so all a bit new to satellite TV. The house has a dish already and there is some sort of co-ax lead in the corner of the lounge that I assume connects to the freesat tuner in the TV. What else do I need?
TV + freesat box + digital dish == Freesat.
wot he said
What's a "digital dish"? I thought a satellite dish was a satellite dish.
I wouldn't dick about like that. I'd get Humax Foxsat PVR, dual or quad lnb for dish and run some shotgun cable into lounge and obviously add HD telly. Father in law has that set up and it's very good.
Oh and try to get an ethernet cable to back of Humax box for iPlayer and all that on demand stuff.
freeview ...freesat
2 different things
has telly got sky freesat decoder?
He hasn't bought it yet...
a few are coming with freesat built in now, so as long as the dish is digital(chances are it is because analogue hasnt been used for years) and its still pointing in the right place(easy to fix if it isn't with a bit of time, patients, and google) a built in freesat tv should be pretty good, everything all in one box. you could maybe borrow an old sky box off someone to plug in and check the dish is all good before you get it
ideally I don't want a separate freesat box, so these things seemed like a good ideA
If you get freesat build into the TV then it won't have recording/pause/etc capability. I'd get a HD telly + a separate Freesat box with a harddisk in it so you can record stuff while you're out etc etc.
Another thing to bear in mind, you;ll probalby need TWO leads from dish to box, if it's a recent (Sky+) installation youll be OK but if the dish has been up for years you may need another cable fitting
Can I use a PS3 as a HDD recorder? I want as few boxes as possible, so:
PS3 for HDD recording and DVD/Blu Ray plaback, internet, iPlayer etc (and of course my old PS2 games!)
The PS3 seems like a really good "one box solution" but I would like to have something like Sky Plus without paying any subscription
You need a standalone Freesat PVR box then.
