Fitting tyres with ...
[Closed] Fitting tyres with the wrong load rating. What will it do?
The car is ment to have 91 fitted. If I put a 95 on will I die?
Posted : 06/10/2015 5:44 pm
In flames.
Posted : 06/10/2015 5:50 pm
You. Tomorrow.
Posted : 06/10/2015 5:52 pm
No, higher is OK ๐Ÿ™‚
But keep the same across the axles and check the speed rating is appropriate.
Posted : 06/10/2015 5:54 pm
Thanks spooky. Northernmatt, that pic is ace
Posted : 06/10/2015 6:13 pm
The tyre caucus will be stronger and therefore stiffer so could give a slightly harder/harsher ride, also the compound maybe harder than a lower rating.
Posted : 06/10/2015 9:01 pm
Just don't put on anything with too low a rating. Too high should be fine, as long as the speed rating is right.
Too low a load rating, and the tyres might as well be made from cling film.
Posted : 06/10/2015 9:05 pm
Ito low on vans for instance and you may have handed your insurance an instant claim rejection after an accident...
Posted : 06/10/2015 11:08 pm
