mikewsmith - Member
2 parts.
Just give a try then we can chinwag about whether it is or it is not.
Selective reading again, you prove it works we will prove it's correlation -quite easily I expect.
In other news, something happened on the way into work.
mikewsmith - Member
Selective reading again, you prove it works we will prove it's correlation -quite easily I expect.In other news, something happened on the way into work.
See another excuse.
Just do it man! What's with all this poncy excuses of attempting to avoid doing some simple experiments?
Like I said before once you have done the experiments then we can discuss all we want. I shall ask you if things have look up/down for you and according to your information, I shall then put my points forward to see if my explanation make sense then we can continue form there so how hard can that be?
We need to start the experiment somewhere so just try it man!
How on earth do you speculatively attribute such atrocity to FS practitioners?
How on earth do deliberately mis-read that as doing so?
The point was FS did shit-all for these people. In short, magic don't work.
For it to be a semi useful experiment you will need a control group and preferably have it blind to both the participant and the main tester. You need someone to sneak round and start banging nails through innertubes or whatever as opposed to having people do it themselves.
Nope. Coz the "results" have already been written so impossible for me to change them. The only thing is to see if those results are consistent with those written.
So why not tell us what they are if they're immutable?
Worried about prior knowledge biasing the result? That's a fair objection. Would you be prepared to write these results down and have them held by a third party for a year if someone were to take you up on your challenge? I'd be more than happy to escrow for that.
It is time to do some experiment so stop that poncy excuse and do it then we chinwag.Rob Hilton - Member
I know that you need control group etc, which we can do after we try this out to see if it is worth leading to proper test innit. I trust the people to try it with honesty after all what is there to gain or to loose? Try it!dissonance - Member
The have their so called results so I just want to compare them myself.Cougar - Moderator
The results can be different for everyone so this experiment is just to give a general hint direction to come and if needs be then the experiments will be done properly by writing the results. Before we proceed with the real experiments we will chinwag again so everything is clear. Do this general experiment now.Worried about prior knowledge biasing the result? That's a fair objection. Would you be prepared to write these results down and have them held by a third party for a year if someone were to take you up on your challenge? I'd be more than happy to escrow for that.
Because we have no way of knowing if FS caused it or a dodgy reheated curry
That is a topic for later discussion ok.mikewsmith - Member
