Extra Tv points fro...
[Closed] Extra Tv points from a freesat dish?
 xcgb
All i want to do FFS is put a Tv in another area of the house, I have a freesat dish on the roof that Sky installed and the Missus wants another TV. I have got another tv with freeview built in, but it seems we live in a very poor freeview area so i need to get a signal from the dish i guess,
people i talk to say i may well need another dish and box or can i just adjust my old ariel to pick up a better freeview signal?
can it really be that hard?
Posted : 16/08/2010 7:50 am
Do you want the other TV to be able to show different channels to the main one?
If so, you'll need another Freesat box & a feed from the dish
Posted : 16/08/2010 7:52 am
You dont really need a new dish just part of it (the LNB), as you effectivly need a seperate cable from the dish per Tv you want run off it (so you'd need a new freesat box also).
I.e. something along these lines: http://www.maplin.co.uk/Module.aspx?ModuleNo=97021
Check the dish you have to see if its just got the one point on it, if it has more so its just putting in an additional cable.
Posted : 16/08/2010 7:55 am
 xcgb
Simon
Ah so, that Lnb fits onto my dish if it has only one point, is it just unplug the old one and bolt that one on? I wont need to reset any gizmo technological stuff?
Ta
Xc
Posted : 16/08/2010 8:00 am
There is a chance that you could mess up the allignment of the dish slightly and thats a right pain in the ass to get back where it should be but that would be my only concern.
It should just be take the old one off put the new one on reconnect the old co-ax (for the existing box) and shove a new one on for aditional boxes.
This is all AFAIK by the way. ๐Ÿ™‚
Posted : 16/08/2010 8:04 am
Don't do a Rod Hull ๐Ÿ™‚
Posted : 16/08/2010 8:08 am
 xcgb
All the pies thanks! i won't wear my slippers!
Uplink I guess I have to go see if i have 2 points or not first and go from there cheers
Posted : 16/08/2010 8:11 am
It probably is worthwhile to mention that my dish used to be a sky dish (installed by previous tenants), only has one connection.
I need to replace mine but where the dish is a right PITA to get to.
Posted : 16/08/2010 8:40 am
