Exposure Diablo Mk8...
[Closed] Exposure Diablo Mk8 issues
Got a 2017 Diablo. Not used much, but it's only lasting about 1hr 30 on a full charge.
When charging it's red then green. But in use it only stays green for about 15 minutes then goes orange then red.
Anything I can do or does it need sending off?
Posted : 08/10/2020 9:40 am
 Del
Hour and a half on high?
Posted : 08/10/2020 9:58 am
Mixture of high and low.
Posted : 08/10/2020 10:02 am
1.0-1.5h on Max is the proper run time for a MK8 Diablo.
The charge indicator seems about right - green indicates above 80%, amber is above 40% red is below 40% red flashing is below 20% or something like that. It's not dropping the beam strengh, just displaying charge status.
The Mk9 and beyond also have green and amber flashing modes, but I can't remember whether my Mk8 did.
Posted : 08/10/2020 10:06 am
That sounds about right for run time given the age.
My MK3 Diablo has a weird issue that when turned off the led indicator flashes constantly.
Posted : 08/10/2020 11:11 am
 cp
you only get an hour on high anyway with the Diablo mk8, so an hour and a half with mixed high/low sounds about right potentially, depending on your mix of use.
Also if it's been off most of the summer, it might take a couple of use/charge cycles to get the battery back to decent life.
Posted : 08/10/2020 11:31 am
