Excel 'informa...
[Closed] Excel 'information' pushed to ical, outlook/google calendar etc
Hello all,
Just had a quick search on the net and I can't see anything obvious, so I will ask the collective STW minds...
I have data in excel that is related to dates in a calendar.
I want to send this data to a calendar(s) that are both my own, and others in a research group.
Is it possible to upload this information to a 'site/server' or similar (this my be incorrect IT speak - please excuse my ignorance) and then have it be 'pushed' to peoples calendars?
Any thoughts would be gratefully received.
Posted : 26/10/2012 10:50 pm
Almost certainly using VBA - you can interact with Outlook and hence Exchange from within Excel, using VBA.
Have a look using Google eg:
http://www.pcreview.co.uk/forums/controlling-outlook-excel-using-vba-t1837173.html
Posted : 26/10/2012 10:52 pm
The simplest way would be to send calender invites, via Outlook, but use Excel VBA to drive Outlook and create / send the invites.
I've got Excel to send emails via Outlook eg notify me, with an email, if an error case occurs in an Excel application.
Posted : 26/10/2012 10:54 pm
Oh, this sounds clever! Thank you. I will have a look now.
Posted : 26/10/2012 10:57 pm
OK, just had a look and the code I used came from: http://www.rondebruin.nl/cdo.htm
Posted : 26/10/2012 11:02 pm
To send an email from Excel VBA:
Public Sub Mail_small_Text_Outlook(ByVal strbody As String, ByVal Recipient As String)
'Working in Office 2000-2010
Dim OutApp As Object
Dim OutMail As Object
Set OutApp = CreateObject("Outlook.Application")
Set OutMail = OutApp.CreateItem(0)
On Error Resume Next
With OutMail
.To = Recipient
.CC = ""
.BCC = ""
.Subject = ""
.Body = strbody
'You can add a file like this
'.Attachments.Add ("C:\test.txt")
.Display
End With
On Error GoTo 0
Set OutMail = Nothing
Set OutApp = Nothing
End Sub
Posted : 26/10/2012 11:04 pm
Footflaps - thank you!
If only I knew what all that lot meant. I will read around the subject a little.
Posted : 26/10/2012 11:13 pm
