Excel conditional f...
[Closed] Excel conditional formatting query
Contain your excitement!
I've got the following rules which highlight a text cell depending on the decimal value of dividing one cell from another - effectively (or not!) highlighting areas based on their percentage.
GREEN =(I15/B15)=0
RED =(I15/B15)>0.33
AMBER =
What formula can I use to highlight in amber those text cells where the calculation result is between 0.33 and 0.99?
I could do a hidden column where I put the result then just use that value to determine colours but it's bugging me how to do it as above!
Thanks in advance.
Posted : 06/01/2021 6:00 pm
do you not just use and AND((I15/B15)>0.33,(I15/B15)<0.99))
I am properly flying by seat of the pants here as I'm sure I alwyas get confused with AND syntax in excel
Posted : 06/01/2021 6:02 pm
You're saying here that > 0.33 is RED but you want between 0.33 and 0.99 is AMBER. Does not compute.
Posted : 06/01/2021 6:05 pm
Thank you both. I think I need to go and have a rethink.
Posted : 06/01/2021 6:09 pm
Thats a good point.
Amber should be 0 to 0.33, red anything above?
as it only goes up to 0.99 will it ever be 1?
if it goes up to 0.991 for eg you'll get no formatting
Posted : 06/01/2021 6:10 pm
Its for showing progress levels of items being processed. Column 'I' is the number of unprocessed items so when all items are done then it should show as 0 hence my original formula. To be honest it's not a major feature but just one of those tasks which happily gets the brain working!
Thanks again
Posted : 06/01/2021 6:21 pm
Any reason not to use an RAG formatting style rather than hand cranking the formulae? (conditional formatting/icon sets, pick whatever suits then back to conditional formatting/manage rules to set the thresholds)
Posted : 06/01/2021 6:24 pm
presuming you want either red, amber or green - if you have conditional formatting for red & green then just format all the cells as amber and then if it meets the condition it'll either turn it red or green.
Thanks again for all your help. I think if there's a next time then I'll do a hidden column and base the conditional formatting on just that instead of multiple cells.
Much obliged 👍
Posted : 06/01/2021 6:30 pm
