I am creating a spreadsheet based on information cut and pasted across from an online website of share information.
Everything is fine until I delete hyperlinks at which point Excel crashes then spends half an hour downloading to MS.
I have tried all hyperlinks and I have tried single hyperlink both have same result.
Is there any way I can copy without hyperlinks or maybe format the sheet to exclude them?
Try:
CtrlA (select all)
CtrlK (hyperlink)
-> Remove hyperlink
Not sure if this will work to remove all the hyperlinks at once, but worth a try
Paste Special >>> Values
Not sure if it will solve your issue, but have you tried this:
RM.
If I cut and paste from web pages I often find it works better to paste into Word first, tidy up there and then paste into Excel. There are more option in search and replace for getting rid of spare line breaks, rebuilding tables with the right columns, etc. If you paste into Word as text the hyperlinks are disabled.
Tried the Word route and it works if I change to local formatting then transfer to Excel.
A bit of a faff but at least it stops Excel crashing.
I will try the other suggestions later.
Thanks for replies.
Ahahahaha
Thols2 has the correct answer and also that Venn is getting copied.
If you paste into notepad instead of word it gets rid of everything except the text and you can then paste straight into Excel. If you use word it will copy a lot of the formatting and possible hyperlinks that need editing out.
I had to something similar once and ended up with the website, notepad and Word open. Copy from website; Alt-Tab to Notepad, CTRL-C, CTRL-A, Ctrl-X to paste and then cut; Alt-Tab to Excel and CTRL-V
It took a while but very quickly the keys=trokes became almost automatic so was faster than I expected.
So,not just me doing that then. It's a pain but it solves so many problems
Alternatively as per the honerouble gentleman
Paste Special >>> values
No faffing about with notepad etc does the job in one right click.
FTFY:
I had to something similar once and ended up with the website, notepad and Word open. Copy from website; Alt-Tab to Notepad, CTRL-V, CTRL-A, Ctrl-X to paste and then cut; Alt-Tab to Excel and CTRL-V
Dunno about Excel, but in Word (and Outlook) you can paste something then tap (not hold) Ctrl and press T and it'll strip all the formatting from what you just pasted.
Though after 8 months of silence I suspect the OP has either solved their conundrum or given up.
