Everyone loves a &q...
[Closed] Everyone loves a "car bump, who's at fault?" question
People in driver B situation not letting others turn right when at most they are going to move a couple more car lengths forward - or actually just block driver A in, are quite annoying IMO.
Annoying maybe but it doesn't make them at fault.
Posted : 02/03/2015 3:29 pm
 D0NK
A as B has right of way and therefore [b]does not need to be able to stop in the distance they can see[/b].
eh?
I'd normally say A aswell, like with rear end shunts it's generally obvious who is to blame, but sometimes the details/circumstances can push it the other way.
agreed, it just makes them arseholes, rule 151 does cover this but again it's a "you should" so no one bothers with it.
Posted : 02/03/2015 3:30 pm
Someone above claimed B needed to stop in the distance they could see so I was countering that [ badly obviously]
Agreed hence why i mentioned excessive speed
or say C stops to flash out A and then B overtakes C and hits A
Posted : 02/03/2015 4:16 pm
 sbob
Still almost always A's fault.
In the OP's case, still A's fault.
You need to be able to stop in the distance you can see is clear, and reasonably expect to remain clear.
It is reasonable to not expect a car to pull out of a minor road into your path.
Posted : 02/03/2015 4:28 pm
I agree with your view FWIW but I thought if you overtake - which you can only do when safe to do so ie you can see its clear they ended up 50/50 as there is always more onus on you when you overtake as its a sort of at your own risk manoeuvre.
Posted : 02/03/2015 4:37 pm
Many years back I was undertaking a large Luton van that was stationary waiting (and indicating) to turn right into a side road. A car coming the other direction also wanted to turn right into the opposite side road (on my left). Due to the van we didn't have line of sight on each other and I hit the side of the car as I was about level with the van when the car shot out in front of me, barely had time to hit the brakes (not that much would have happened see below). Following that after accident moment of "oh dear" where you gatther your thoughts as you take in what has happened, I looked up to see the two occupants out of the car and legging it away. Turned out the car had been stolen a couple of days before. Police attended and agreed the other car was at fault, possibly the fact it was stolen played a part in their view, but it shouldn't really have a baring. However as they were not caught I had to take the damage on the chin, not that claiming from them would have likely yielded anything. I'm thankful I was in a Series 3 Land Rover, so only suffered a bent bumper and slightly bent wing. The Astra I hit was likely a write off with the front side wing/door area stoved in and my bumper had taken the top of the wheel in so it was almost horizontal.
Posted : 02/03/2015 4:42 pm
if you overtake
If I understand the OP correctly, B was not overtaking but using the second (outer) lane and the bus was stationary in the inner lane.
Posted : 02/03/2015 4:44 pm
Yes i am describing a totally different scenario.....which i did in my clarification point to another unclear post
The fail is with me today 😳
Posted : 02/03/2015 4:54 pm
Page 2 / 2
