Enamel bath repair
[Closed] Enamel bath repair
What is the view on repairing a chipped enamel bath?
Is it worth bothering with DIY kits?
I’ve seen some less than positive DIY results from the £30ish kits with yellowing soon after, or repair being very obvious.
After dropping a hammer in the bath which left a 30mm chip, I’m trying to decide whether to DIY, get a professional to spray entire bath, or just replace bath.
Posted : 31/07/2019 8:47 pm
 kcal
I did - this was many years ago - get the bath doctor or some such guy to come and repair / reskin an old enamel bath. I think it was effective for a while, but did eventually lift off round the plughole. For chips it might be enough to keep going for a bit longer. I'm not sure it's a very long term solution (unless the techniques have improved).
Posted : 31/07/2019 8:51 pm
For DIY you could try Miliput epoxy putty in white. You can shape and mold it with water. You can sand it when dry. I've filled a few smaller chips around the edge of a cast iron bath with it.
Posted : 31/07/2019 9:33 pm
