I just use the free version of Sketchup which is fine for most of my needs however the one thing it doesn't allow you to do is import .dwg files into it.
Does anyone on here have access to the pro version of it? If so, if I send you my dwg file would you be willing to import it and send me back the .skp file?
Otherwise does anyone know any cheeky way to do this without paying for the pro version?
Cheers!
It used to be when you downloaded a copy of the free version you got a time limited version of SketchUp Pro to play with. Can you not still do that?
Or are there any plugins in the SketchUp library that will do the job?
*Edit...
This YouTube link describes a way if doing it using an older version of SU to save the file, and then open in the latest version....
SketchUp DWG
