Dirtworker replacem...
[Closed] Dirtworker replacement hose?
[#11984492]
My aged (15+ years?) Dirtworker has had a leak where the hose enters the main apparatus for a while but it otherwise works fine. Anyone know if these hoses are standard and can be replaced? As far as I know, Dirtworker is no longer a thing, unless anyone knows different?? Thanks!
Posted : 02/08/2021 4:40 pm
Could just be the o ring. Thats what leaked on mine. Replaced and worked perfectly. Having said that shortly after it started leaking at the plastic tgrough fitting where the hose leaves the tank and enters the pump. I replaced that with a nice brass connectorand then it started leaking at the float switch. I can't find a float switch but can find a new pump motor with integrated float switch. By the time i've done all of this i'll have spent more than a new pump and will probably have a leak somewhere else!! Theres a moral in there somewhere but i like fixing stuff
Posted : 02/08/2021 5:29 pm
Mine's where the hose enters the tank where it's leaking. Good shout on the o-ring. Might see if I can address that first, thanks!
Posted : 02/08/2021 7:11 pm
