I have a fish-eye style wide-angle lens, are there any free packages out there for correcting the distortion (I expect a little detail loss in the corrected areas) or am I going to have to dig out the old code books and write one?
there is a button to press in paintshop pro that does it but you have to pay for PSP
You get a free 10 image trial with [url= http://epaperpress.com/ptlens/ ]PTLens[/url]
Oooh I never knew that about PSP, I have that free with work (and I dont have any dodgy copies at home at all!). I'll hunt it down, thanks.
If I cant find it I'll find PTLens and reverse engineer it ๐
Also if you use Nero for CD burning then some versions come with Nero Photosnap, which has a really simple function called "Lens distort" in which you can "pin cushion" the image, this reduces/removes the barrel effect caused by the fisheye
PSP / Photoshop correction is for barrel distortion from cheap wide angle lenses isn't it, will it work on a fish eye lens? a proper fisheye has really pronounced distortion so may be better off just using a non fish eye lens?
