Cloakroom rad - ins...
Cloakroom rad - inspiration please
 DT78
Its a very narrow space approx 80cm wide. Its also cold as it used to be a larder.
I need to fit some form of heating in there. Only place is opposite the door, so as well as fitting close to the wall I'd like it to look ok.
Ideas? Plan was a single rad but they look ugly. Nice towel rails project into the space too much.
UFH not really an option solid floor with no insulation
Posted : 27/10/2022 6:05 pm
Towel rail
We fit alot of these for customers, simple, efficient, and colorful
Posted : 27/10/2022 6:10 pm
 DT78
they look nice! I cant see but do you know roughly what the projection is like?
Posted : 27/10/2022 6:45 pm
Fit an underfloor heating system in the wall, not as daft as it sounds ๐Ÿ™‚
Posted : 27/10/2022 8:14 pm
80mm projection from wall, I have a neon pink on my downstairs w/c
As above you could use electric ufh on the wall, but you probably won't have enough wall area for it to be effective, as is normally 195watts per square metre
Posted : 27/10/2022 9:39 pm
